98 Integra Maintenance Required (Re-Calibrate) - Reprogram?
Old Jul 23, 2015 | 12:32 PM
anoble1's Avatar
Default 98 Integra Maintenance Required (Re-Calibrate) - Reprogram?
Is there a way to change this to where it comes on at 5,000 or 4,000 miles instead of the standard?
Anyone ever done this or heard of it?
Old Jul 23, 2015 | 02:07 PM
B_Swapped93's Avatar
Default Re: 98 Integra Maintenance Required (Re-Calibrate) - Reprogram?
No.... just write down when you changed your oil OR W/E if you want to do it every 4k, it's an oil mechanical style counter nothing you can do.
Old Jul 24, 2015 | 06:09 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
I'm sure there's a way to reprogram it so that the light turns on every 4 or 5k instead of 7500. But.....I don't believe there is some easy hack that's been documented. Get a wiring diagram and figure out how it works. Maybe you can switch a resistor or something easy. If its solid state, and you're savvy enough to reprogram it....well...you wouldn't be asking this question....
If that sounds like more trouble than it sounds like a fun project....try writing your mileage in an excel sheet with a calculated cell that adds 5k miles to whatever number you plug in for "current miles".
Its harder to lose than a piece of paper.
The other ways to keep track of your mileage are obvious and less creative. So I won't insult you by mentioning them.
PatrickGSR94
Aug 31, 2017 10:04 AM
gina
Aug 26, 2006 10:52 AM
Nextelbuddy
Feb 27, 2004 06:08 AM
Ross
Sep 13, 2002 03:38 PM
R-gonaut
33
Jul 31, 2002 10:40 AM
