99 vogue silver 4dr, all-in, sheepey, comp bb
Old Jul 22, 2015 | 07:42 PM
b18cya94's Avatar
Default 99 vogue silver 4dr, all-in, sheepey, comp bb
Well I pretty much changed my whole setup and repainted and powder coated everything. Here's a run down.
Engine:
B18c1 81.5mm 10:1
Knife edged eagle crank
Eagle Rods
CP pistons
Billet main girdle
Head studs
Je head gasket
Fluidamper crank pulley
B16 head P&p*
Dual Springs and ti retainers
Rocket motorsports custom cams
Bisimoto cam gears
Locash cnc valve cover
K series cop
Aem epm*
Aem ems*
All-in intake mani
All-in tucked rad/intercooler
All-in swirl pot
All-in murder kit
S90 74mm tb
Id2000 injectors
Sheepey top mount with 3" dp
Comp 5858 billet bb ported housing*
Tail wg
Tial bov
Downstar everything*
Trans:
B16 with carbon syncros*
Quaife lsd
Comp stage 5 clutch
Comp flywheel
Insane shafts axles
Brakes:
Wilwood 4 piston calipers
Slotted rotors all around*
Rear disc conversion
Finishing lines brake tuck kit
Suspension:
S2 pro front camber kits
Hardrace tierods
Buddy ball joints
J2 bearing front lcas
Koni yellow with ground con coil overs*
Pw jdm bearing rear camber kit
Pw jdm bearing rear toe adj
Pci tailing arm bearings*
Asr brace with sway bar
F7 billet lcas
Old Jul 22, 2015 | 07:43 PM
b18cya94's Avatar
Default Re: 99 vogue silver 4dr, all-in, sheepey, comp bb
Old Jul 23, 2015 | 11:20 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Been following on Instagram, it's coming along great man!
BTW, he did did almost all this work himself and with friends.
Post a pic of the bay!
Old Jul 24, 2015 | 12:18 AM
crazydominicanman's Avatar
Nice to see you using the billet valve cover. Sweet build.
Old Jul 26, 2015 | 07:10 AM
Axix24's Avatar
This is the worst thread ever. Where are the pics of car and bay? I mean geeze. 👎
Old Jul 26, 2015 | 04:51 PM
ChadB's Avatar
Pic would be nice
b18cya94
Jul 23, 2015 10:44 AM
b18cya94
Dec 28, 2012 04:43 AM
hondaclassifieds
Mar 5, 2009 12:53 PM
Boostedb20EH2
Jul 25, 2008 08:43 AM
zdalunatic
Mar 3, 2008 11:27 AM
