99 vogue silver 4dr, all-in, sheepey, comp bb
Old 07-22-2015, 02:31 PM
b18cya94's Avatar
Default 99 vogue silver 4dr, all-in, sheepey, comp bb
Well I pretty much changed my whole setup and repainted and powder coated everything. Here's a run down.
Engine:
B18c1 81.5mm 10:1
Knife edged eagle crank
Eagle Rods
CP pistons
Billet main girdle
Head studs
Je head gasket
Fluidamper crank pulley
B16 head P&p
Dual Springs and ti retainers
Rocket motorsports custom cams
Bisimoto cam gears
Locash cnc valve cover
K series cop
Aem epm
Aem ems
All-in intake mani
All-in tucked rad/intercooler
All-in swirl pot
All-in murder kit
S90 74mm tb
Id2000 injectors
Sheepey top mount with 3" dp
Comp 5858 billet bb ported housing
Tail wg
Tial bov
Downstar everything
Trans:
B16 with carbon syncros
Quaife lsd
Comp stage 5 clutch
Comp flywheel
Insane shafts axles
Brakes:
Wilwood 4 piston calipers
Slotted rotors all around
Rear disc conversion
Finishing lines brake tuck kit
Suspension:
S2 pro front camber kits
Hardrace tierods
Buddy ball joints
J2 bearing front lcas
Koni yellow with ground con coil overs
Pw jdm bearing rear camber kit
Pw jdm bearing rear toe adj
Pci tailing arm bearings
Asr brace with sway bar
F7 billet lcas
Old 07-22-2015, 02:33 PM
b18cya94's Avatar
Default Re: 99 vogue silver 4dr, all-in, sheepey, comp bb
Old 07-22-2015, 05:10 PM
b18cya94's Avatar
How do I post pics? It's been a while lol..
Old 07-22-2015, 11:51 PM
mr.4drtoyou's Avatar
Just thougt i give you a heads up, i've seen those front lower control arms break... Unless the car is going to be a true track car where it will not see any street driving then your ok...
Old 07-23-2015, 12:35 AM
Who is Mr Robot?
wantboost's Avatar
I've been wanting one of those valve covers for a while now
Old 07-23-2015, 01:46 AM
COM2's Avatar
Nice setup. What are your goals for the car?
Old 07-23-2015, 02:15 AM
Who is Mr Robot?
wantboost's Avatar
He's local, IIRC it's a pretty nasty highway car
Old 07-23-2015, 10:44 AM
b18cya94's Avatar
I built the car to cruise every once in a while it's not a dd. Lol the arms would be ok if not I'll put the factory ones back on.
b18cya94
07-26-2015 04:51 PM
b18cya94
12-28-2012 04:43 AM
hondaclassifieds
03-05-2009 12:53 PM
Boostedb20EH2
07-25-2008 08:43 AM
zdalunatic
03-03-2008 11:27 AM
Quick Reply: 99 vogue silver 4dr, all-in, sheepey, comp bb
