Mini me question
Old Jul 18, 2015 | 07:28 PM
Dcr90's Avatar
Default Mini me question
I have been searching threads and Google for a few days now but can't answer this question.
I have a 97 civic not sure what trim model. Has the 5spd d16y7 motor.
I just got a y8 head, intake and everything. But when I got the set up it came with a p2p-a31 ecu. Which I believe is obd2a, my current ecu is a p28 and the plugs appear to be obd2b because it doesn't use the far right plug.
I thought 97 was obd2a? Does this mean I need to get a p2p obd2b ecu? Hoping to do the swap in a few weeks and want to make sure everything is correct.
Old Jul 18, 2015 | 07:55 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: Mini me question
sparky, you've got obd2a. the ecu is correct as long as its obd2a.
Old Jul 19, 2015 | 09:45 AM
Dcr90's Avatar
I was wrong, my current ecu uses all four plugs.
Old Jul 19, 2015 | 11:57 AM
NotARaCist's Avatar
I never narc'd on nobody!
Are you really trying to modify an autotragic? Stop that. It doesn't work that way. Then go read the rules sticky.
Old Jul 19, 2015 | 12:58 PM
4 plugs= automatic
Old Jul 21, 2015 | 10:52 AM
Dcr90's Avatar
Car was converted over to a manual but apparently still has the old ecu on it. I bought it that way.
That's what I couldn't figure out because all of the pictures of ecus only used three plugs. I'm learning alright, just be happy I'm getting rid of my eclipse and got a civic haha.
Old Jul 21, 2015 | 12:26 PM
get rid of the a/t ecu. youll need a manual ecu and to do a 3 to 2 wire iacv conversion.
Old Jul 21, 2015 | 05:54 PM
Bently_Coop's Avatar
Steve at Heart
You might be able to remove resistors disabling the A/T for the ecu. I know the OBD1's are like that.
Old Jul 22, 2015 | 01:19 AM
Dcr90's Avatar
I'm getting ready to make her right
Just trying to make sure I have everything correct before I rip into it. I should, it's the 4 plugs on the ecu is what messed me up.
wushubrian
Jan 25, 2007 02:43 PM
RickyBizee
Nov 19, 2006 05:18 AM
PrestonCRX
Mar 16, 2006 06:09 PM
WCI
Nov 9, 2003 08:17 PM
