Pressing in new bushings on a 93 Civic EX coupe
Old Jul 16, 2015 | 11:17 AM
angrysmileyface's Avatar
Default Pressing in new bushings on a 93 Civic EX coupe
So I have purchased a bushing kit to replace my aging 23 year old OEM ones. From all the research I have done on the topic (IE various ways of removal such as torch, drilling, and press) I have found conflicting information as some say the old bushings are tapered and pressed in with directionality. How do I know which direction to press them out if the metal sleeves are flush or is there no taper and they can go in and out from either side? I know rear trailing arm bushings have the directionality (but I replaced those a year ago and will not be replacing them again). I can measure the new bushings to see if there is taper on them, but I want to confirm from the veterans of this process if there is
A directionality of insertation/removal
and
B if the taper (if existing) is significant.
I appreciate the info.
Thanks in advance.
Old Jul 16, 2015 | 02:48 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Pressing in new bushings on a 93 Civic EX coupe
Are you replacing with OEM bushings?
If you are, I would get the bushings in and then you can measure them and/or visually inspect them to see if they are directional.
If you aren't going OEM, then I understand the dilemma.
Old Jul 16, 2015 | 04:54 PM
tony_2018's Avatar
Fish Twig
From what I've seen. They can go in either way. Just make sure you jack up your arms to the actual height of when the car is actually touching the ground with wheels on and torque them down properly.
Old Jul 16, 2015 | 06:25 PM
Nonoem. I'm going hardrace 6107 kit
Old Jul 24, 2015 | 01:03 PM
Side question, does the OEM bushings have taper and a requirement for direction to be pushed out?
Old Jul 24, 2015 | 04:07 PM
tony_2018's Avatar
Fish Twig
why not take a look at the bushings on your car....better answer.
Old Jul 24, 2015 | 04:50 PM
98civdx's Avatar
Master Detailer
If they have one, I've never seen in it. I've done bushings a few times, including my car. I've never seen a taper on the sleeve.
Have fun, it's definitely going to **** you off a little.
Old Jul 25, 2015 | 05:22 AM
Not to be rude, but I'm only asking to facilitate easier removal. As for the fun pa rt I expect it to be a royal pain in the ***, all though this car has never seen salt in excess
Old Jul 25, 2015 | 05:33 AM
tony_2018's Avatar
Fish Twig
If it was tapered I would assume hardrace would've done the same and not deviate from the original design.
Old Jul 25, 2015 | 05:00 PM
98civdx's Avatar
Master Detailer
Neither did mine. Those are the bushing sleeves. Not the smashed one. That was over 2 hours to get that one out.
A quick tip, if your burning out, cut more 1 slit in the ring. 3-4 is ideal. I did 1-2 on mine and it sucked. 3-4 on my buddies and they weren't nearly as hard to get out.
Old Jul 25, 2015 | 07:09 PM
tony_2018's Avatar
Fish Twig
So you're saying the bushing sat inside the tapered sleeves?
Old Jul 26, 2015 | 02:22 PM
98civdx's Avatar
Master Detailer
Um no. with that said, if you look at the 2 bushings with the "flange" they obviously only go one way. The others it doesn't matter.
The sleeves can be very difficult to remove, but cutting slits in them does help a lot.
Old Jul 26, 2015 | 02:43 PM
tony_2018's Avatar
Fish Twig
What location are these bushings? rear lca?
Old Jul 26, 2015 | 03:37 PM
98civdx's Avatar
Master Detailer
Front LCA
Old Jul 26, 2015 | 03:40 PM
tony_2018's Avatar
Fish Twig
Interesting, the hardrace bushings that I've seen didn't have tapered sleeves.
Old Jul 26, 2015 | 03:56 PM
98civdx's Avatar
Master Detailer
I'm really not sure where you are getting that they are tapered. I never once said they were, in fact I said they weren't.
Old Jul 26, 2015 | 05:50 PM
joey1320's Avatar
The bushings are not tapered but the inner bushing does have a "crown" on it, which means that it should only go in one direction - just match the oem one.
As far as the removal and install - remove the arm, burn the bejeezus out of the inner sleeve and rubber, so that you can push out the inner sleeve easily.
Once you remove the metal inner sleeve, take a sawsall and cut 4 slits into the rubber and metal outer sleeve. Make sure you cut through, without cutting too much into the arm.
After making the slits, once again heat up the outer part of the control arm and take a chisel and hammer it out. If not take a right-sized cup/presser/socket and press out the outer sleeve.
Old Jul 26, 2015 | 06:03 PM
joey1320's Avatar
Press out the inner sleeve after burning off the rubber
The press them out.
Old Jul 27, 2015 | 08:32 PM
tony_2018's Avatar
Fish Twig
My bad, that day I responded I was all kinds fucked up. I was talking about the lip that OP is referring to. I don't recall there being one.
Old Jul 28, 2015 | 03:12 PM
98civdx's Avatar
Master Detailer
I've never seen hardrace bushings first hand. I honestly have no clue if they have the lip or not. They might not, might just be a Honda thing.
Old Jul 29, 2015 | 05:55 AM
purgat0ry's Avatar
I've owned three sets.
The only one that has a lip/crown is on a 99-00 kit, the inner guy (See below)
Otherwise, none others have a taper.
OP; there is also a pretty decent write-up in the FAQ if I remember correctly.
Old Jul 29, 2015 | 07:35 AM
street_racer_271's Avatar
i pressed all mine out, whatever way fit best on the press, didn't have any issues
Old Jul 29, 2015 | 03:05 PM
98civdx's Avatar
Master Detailer
I guess I could have mentioned mine came out of EM1 LCA's.
Jon Petersen
Dec 19, 2018 06:12 AM
angrysmileyface
Apr 22, 2014 05:19 PM
DJKellogg
11
Apr 1, 2014 10:47 AM
Fastguy
Sep 8, 2011 07:52 AM
reefer_bob
Mar 30, 2004 06:12 AM
