01 Civic EX Issues
Changed the Tranny to an 05 and at first was having a problem getting upto speed the more gas I gave it the worst it got til it back fired shuttered and shut off. Think I got that handled but now the SRS system seems to be going into complete failure mode 126k on the car and the srs had no issues before I switched Tranny's Ran a Scan and it basically says failure at ea. sensor. Here are the codes pulled
P1298
B1600
12-01
I have no books on the EM2's as I have only worked w/ the 96-98 EK's and I haven't had this one for long
P1298
B1600
12-01
Here's how it reads from the scan tool on the ABS System.
1. Right Front Wheel Speed Sensor Signal Malfunction
2. Motor Voltage Malfunction 1
3. Motor Power Supply Voltage.
4. A Problem w/ Voltage for Torque sensor PVF
5. A Problem w/ voltage for torque sensor PVF
6. Low/High VBU voltage( Regular Diagnosis)
7. Right Front Wheel Speed Sensor Failure
8.Right rear speed sensor signal error
9. Mismatch contact 1 and contact 2 of Released switch
10. Lateral Acceleration Sensor Malfunction
DTS for SRS B1600
Honda SRS Permanent
1. Keyless Access Control Unit Bus Line Error (Bus Off)
2. Communication Bus Line Error
Any help w/ explaining what any of this means is well appreciated
Thanks
Honda SRS Permanent
Thanks
Hey, I'm having this exact code with my 2002 Civic. Do you remember what the problem ended up being?
Basically your keyless entry is disabled. Shouldn't effect your drive-ability though
