92 Civic - need help reading codes obd1
Old Jul 13, 2015 | 10:09 AM
redbull99's Avatar
Default 92 Civic - need help reading codes obd1
New to the obd1 from what i read and from what i understood 1 long flash is code 10 1 short flash is 1. its a eg gsr swap heres a link to video of the flashes
my understanding is this
Code 7 = TPS
Code 23 = Knock Sensor
Code 41 = o2 sensor (on header)
Code 45 = Fuel System too rich or lean
I don't know why its showing o2 sensor because i bought the subharness from rywhire and spliced it into the ecu , it came with Green , Red,Black, White Colors, From what i read Black and white are heater wires
Thanks in advance
Old Jul 13, 2015 | 12:12 PM
tony_2018's Avatar
Fish Twig
Default re: 92 Civic - need help reading codes obd1
What ecu, why not use your own harness from the eg? Why did you need to splce any wires when the ecu plugs, minus the secondary butterfly solenoid. I don't see a code 45.
Old Jul 13, 2015 | 08:30 PM
redbull99's Avatar
p72 obd1 gsr ecu, and i think the eg harness was used , i "spiced" the wires to the ecu because there was already wires connected to the ecu pins that i needed to connect the o2 sensor so people from this forum said spice them into the wires
Old Jul 13, 2015 | 09:34 PM
Former User's Avatar
If you reset the ECU, do all those codes return?
Old Jul 14, 2015 | 02:41 AM
HondaPartsHero's Avatar
Technical Hero
Is this it? If so did you hook up the knock sensor? Check to make sure you didn't switch the TPS and MAP sensor connectors around. And recheck your 02 wiring but unless your car was a CX with a one wire 02 you shouldn't have had to wire up that portion. What is your year, make model?
Old Jul 14, 2015 | 04:52 AM
tony_2018's Avatar
Fish Twig
So you're saying you ran your own o2 sensor? Don't splice that **** in, you need to replace it completely.
Old Jul 14, 2015 | 07:15 AM
redbull99's Avatar
Default Re: 92 Civic - need help reading codes obd1
It's a 92 civic si with gsr engine and tranny, so if there's already some wires running to the ecu where I was suppose to plug the 4-wire o2 sensor take them out and plug in the O2 ?? Can someone tell me what the green white black and red O2 wires are
Old Jul 14, 2015 | 07:17 AM
Do you have the service manual? If not, Google search it.
mx621
Oct 27, 2005 01:48 PM
Phatch99
14
Jul 30, 2004 02:55 PM
integlikewhoa
Mar 12, 2004 05:32 AM
R6Elmo
Sep 10, 2003 10:58 AM
Hondasaurs
Apr 25, 2003 02:19 PM
