Quick p28 ECU Q
Ordering a new chipped obd1 for my b20b, going with the demon/neptune combo and I just wanted to confirm that the p28 would work fine with my b20b, I do realize that it is meant to be for a vtec engine but I can use the neptune to allow it to function perfectly on my stock b20 no?
Only other thing I was a little confused on is that it seems you need circuitry onboard the ecu to run boost control, should I just buy the combo that includes it installed? Or would it be worth just installing myself, as I am unaware if manual boost control requires it and if it is really worth getting the EBC circuitry already installed.
That's the whole point of a EMS - tune it for your setup. At that point the stock ECU has absolutely nothing to do with it.
Can you desolder and solder circuit boards? If yes, then take a shot at it. If not, then don't do it yourself. Pay for them to be installed...
That's the whole point in running a Manual Boost Controller (MBC) over a Electronic Boost Controller (EBC)... one requires extra electronic components and wiring the other requires nothing electrical. So which one are you running? That will tell you if you need the extra electrical components or not.
You should probably take everything to a shop to help yourself out.
Instead of a P28, why not grab a cheap P06 from the salvage yard or eBay?? If you're new to FI, I would suggest not even bother with a boost controller. Bad things will happen I guarantee.
I don't see how a manual boost controller being a guaranteed bad idea. It had to be tuned anyway. If he decides to get overzealous, that's his issue.
That's no different than saying, if you're new to driving, don't buy a car. People do stupid things all the time in normal situations.. If trained and tuned add to how to conduct oneself with a turbo cat, you're fine. No different than anything else.
So is the issue with boost creep on the mbc really that big of a deal? I may just go mbc for now as it is my first build.
I suppose you are insinuating that I will most likely overboost while using a boost controller? I know mbcs have creep issues, but I don't see how this is relevant for ebc. I was only going p28 because I was unaware it wasn't needed for using vtec down the line, as well as this being more of a lazy buy and getting it combo'd with neptune and moates, I am now taking your suggestion into consideration however.
Most folks who are new to FI are "trigger happy" and tend to crank up the boost if they have the means to. Then **** blows up and they wonder why it doesn't run right afterwards.
