Fuel lines for 350hp.
Old Jul 12, 2015 | 02:21 PM
GT500FTW's Avatar
Default Fuel lines for 350hp.
what diameter fuel line or AN fittings are you guys using for 350hp?
Old Jul 12, 2015 | 02:24 PM
B20VtecVillain's Avatar
Default Re: Fuel lines for 350hp.
I'm making 450hp with my B20V/GTX3076R Si and Im running -8/-6 lines.
Old Jul 12, 2015 | 02:32 PM
Aradin's Avatar
Premium Member
Stock is more than plenty for 350. Lots of people running in the 500-600 range with stock lines.
Old Jul 12, 2015 | 02:37 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Stock is MORE than adequate.
Old Jul 12, 2015 | 04:54 PM
TheShodan's Avatar
Moderator
Stock for 530whp here
Old Jul 12, 2015 | 06:26 PM
Stock fuel rail and lines will def handle upwards of 500 for sure with just a pump and injectors. The only reason I have steel AN lines is because I'm still running a 10 gallon cell in the spare tire well of the trunk with my pump and pickup/returns all ran through there and the stock tank, lines and fuel rail were all donated to a buddies swap project. I have definately seen numerous people using stock B series fuel rails and lines for about as much power as the stock ignition is good for. Seems like everything stock will support up to Atleast the 500 mark, Honda definately engineers some good products.
Old Jul 12, 2015 | 06:54 PM
wantboost's Avatar
Who is Mr Robot?
At your power level the only reason to move to AN fittings is really for appearances...
Granted if you run new lines from the tank to the motor you can eliminate the aged OEM lines and eliminate a potential failure point like debris hitting a rubber line and puncturing or cutting it. AN lines are much stronger in that regard.
Also if it's a situation where ease and speed of removal/replacement of lines, such as a track car, then AN fittings also have the advantage over rubber lines. I mean how many of us have damaged a rubber line because it gets stuck on a fitting lol
Old Jul 12, 2015 | 07:02 PM
hardcore97's Avatar
stock lines to filter, -6 to rail and i make 500 whp
Old Jul 13, 2015 | 04:46 AM
LightningTeg's Avatar
Community Builder
Stock from tank and back.
jdm_h22
Dec 4, 2012 03:16 PM
Boostfed86
Feb 12, 2009 05:37 PM
TurboB16A300Hpteg
Feb 25, 2008 06:08 PM
greasemonkee
Jun 19, 2007 09:45 AM
gendai_8
Jul 16, 2003 09:43 PM
