B16A2 cams upgrade setting
Old Jul 12, 2015 | 01:57 PM
JAndrinich's Avatar
Default B16A2 cams upgrade setting
Hi, I have a eg6 with a b16a2 engine, recently y bought b16b camshaft and I put them on. The problem is that when I run my cams setted up "0" degrees I/E my car is slower that what it was, it gets better when I set the cams to In + 3(advance) and Ex -1(retard). I know the b16a and b16b have different vtec lobe specs (duration and angle) but I can't find the same information from the primary lobe so I can use that to set my cams correctly, do you guys have this information? Or any idea how this cams should be setted up? Thank you
Old Jul 12, 2015 | 04:08 PM
DumpdEJ6's Avatar
I like the tuna here
Default Re: B16A2 cams upgrade setting
Have you had the car tuned for the new camshafts? If not, that is likely why you are lacking power. They will have a completely different fuel map needed.
Old Jul 13, 2015 | 02:30 PM
JAndrinich's Avatar
I have a p30 Ecu chipped for the cams and other bolt-ons that I have. But my doubts comes from the proper cam set up, because I've seen b16a2 oem cam have a 111deg center angle and b16b has a 101deg center angle, and for the exhaust b16a2 has a 101deg center angle and b16b has a 103.5deg angle. With this information how can I get the proper cams setup?
Old Jul 21, 2015 | 10:06 AM
JAndrinich's Avatar
Nobody?
Old Jul 21, 2015 | 10:28 AM
purgat0ry's Avatar
As this guy said...
Go get a proper tune and stop jacking with it.
allmotaR
Northwest (Sales)
Dec 4, 2012 10:03 AM
panda_eh2
Apr 18, 2008 12:17 PM
Wafler
Apr 29, 2007 01:38 PM
tunes12
Oct 17, 2002 08:02 PM
