2000 EX Coupe Disc Brake top bolt hard to remove
Old Jul 12, 2015 | 12:20 PM
zturek's Avatar
Default 2000 EX Coupe Disc Brake top bolt hard to remove
Having issues getting the top bolt off of the front disc brake.
I have tried PB lube to help loosen. I have issue with
both front brake.
I must be doing something wrong.
Old Jul 12, 2015 | 12:37 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 2000 EX Coupe Disc Brake top bolt hard to remove
Because you've rounded the **** out of it. Are you using the correct size socket or wrench? Lefty loosey...
Old Jul 12, 2015 | 04:57 PM
zturek's Avatar
Got the bottom one off with the same wrench, same direction no problem
I know I rounded it off a bit DUH
Old Jul 12, 2015 | 05:11 PM
NotARaCist's Avatar
I didn't ask if you used the same wrench. The only tools that should be touching that bolt are either a 6 point, 10mm socket, or a 6 point, 10mm wrench. If you're using something else, stop. Go spend the $2 to buy the correct tool. It's also quite clear from the way it's rounding that you aren't fully seating the tool on the bolt (you're doing it wrong), and that you aren't applying even force (you're doing it wrong).
Stop doing it wrong. Stop using the wrong tool.
Old Jul 12, 2015 | 06:04 PM
zturek's Avatar
point taken
theeogflip
Nov 8, 2009 10:45 AM
b17gsr
Mar 25, 2006 08:05 PM
94gsr_vtc
Jun 22, 2005 08:57 AM
KayOs
Aug 18, 2002 10:35 PM
civicracer1993
Apr 18, 2002 07:50 PM
