2000 EX Coupe Disc Brake top bolt hard to remove
Having issues getting the top bolt off of the front disc brake.
I have tried PB lube to help loosen. I have issue with
both front brake.
I must be doing something wrong.
both front brake.
Re: 2000 EX Coupe Disc Brake top bolt hard to remove
Got the bottom one off with the same wrench, same direction no problem
I know I rounded it off a bit DUH
I never narc'd on nobody!
I didn't ask if you used the same wrench. The only tools that should be touching that bolt are either a 6 point, 10mm socket, or a 6 point, 10mm wrench. If you're using something else, stop. Go spend the $2 to buy the correct tool. It's also quite clear from the way it's rounding that you aren't fully seating the tool on the bolt (you're doing it wrong), and that you aren't applying even force (you're doing it wrong).
Stop doing it wrong. Stop using the wrong tool.
civicracer1993
04-18-2002 07:50 PM
