B16 Tach question
Old Nov 4, 2002 | 08:22 PM
Fabrik8's Avatar
Default B16 Tach question
Does anyone know if a CRX Si tach will properly (accurately) display the whole RPM scale that a B16 can go to, like up to 9000 RPM..? I'm buying an Si and doing a B16 swap but I want to find out if making the tach look right for a B16 is as easy as getting a different (higher RPM) gauge face for the stock tach, or will I have to get a JDM cluster of some sort... Anyone have any thoughts or personal experience?
Old Nov 4, 2002 | 08:28 PM
Fabrik8's Avatar
Default Re: B16 Tach question (ridge racer 2)
Well I'm not too worried about overall accuracy, I just want it to look like a B16 tach should, like my VTEC del sol or a 99 etc Civ si... Do you think that the stock tach will rotate that far, or actually read that?
Old Nov 4, 2002 | 08:34 PM
johnzm's Avatar
Default Re: B16 Tach question (Fabrik8)
i have a 90 civic SI and no way my tach would read out 9k. itll probably hit the bottom at 8500.
Old Nov 4, 2002 | 08:38 PM
Malgerus's Avatar
If you're talking about stock CRX tachs, they can be horribly innacurate. I know a guy who shifts his A6 at 8000 on his ctock tach, while the dyno says 7200.
Raene's is pretty accurate, but it seems to depend on the car. I would just go aftermarket if you can!
Old Nov 4, 2002 | 09:06 PM
EF_LSVtec's Avatar
Default Re: B16 Tach question (Mr. S)
Just go to ebay and get this for $125...
Old Nov 4, 2002 | 09:50 PM
88EF's Avatar
Default Re: B16 Tach question (EF_LSVtec)
How did you wire it?!?! Was it that hard?
Old Nov 4, 2002 | 09:56 PM
EF_LSVtec's Avatar
Default Re: B16 Tach question (88EF)
Wiring is not really simple just need common knowledge...like common sense, lol...you have to replace your VSS with an electronic one and wires are usually same color code from the stock plugs to the new cluster except for 3. I posted a couple of links last week regarding this topic..pls run a search its available. Or pm me if you need anything else.
Old Nov 5, 2002 | 05:22 AM
Fabrik8's Avatar
You brought up a valid point about the use of foreign clusters. I think it's really about using an odometer from a different car so the correct vehicle mileage won't be displayed. Does anyone know if just a JDM tach can be swapped in, without the rest of the cluster, to sidestep the logal issues??
Old Nov 5, 2002 | 05:40 AM
xtrafastcivic's Avatar
who cares.... put your stock one back if needed to...
Old Nov 5, 2002 | 06:45 AM
EF_LSVtec's Avatar
No you cant...you can always convert your actual mileage to kmh and adjust your odometer if you're really worried about getting cited.
Old Nov 5, 2002 | 06:48 AM
Phatwhippin_CRX's Avatar
either way, OEM tachs are rarely accurate, same goes for OEM speedos above 100mph......
Old Nov 5, 2002 | 07:53 AM
keebler65's Avatar
Default Re: B16 Tach question (Phatwhippin_CRX)
i know the oem tachs arent accurate, but do they really need to be? as long as you know where it is on your tach that you should shift, thats all thats really important IMO. on my setup, my b16 hits the rev limiter right at the end of the tach's display. so i just know when to shift based on that, even though the actual numbers probably arent 100% accurate. i guess it all depends on your application.
Old Nov 5, 2002 | 11:54 AM
Fabrik8's Avatar
Default Re: B16 Tach question (keebler65)
I just want a tach that is scaled right for a B16, the JDM SiR seems like the way to go.... Now about that KPH instead of MPH
Old Nov 5, 2002 | 01:28 PM
gutted spec's Avatar
New User
You learn to live with it....I've had mine for over 2 years and I am very used to it. Just to add something, if you have an '88 or '89 car (like me), you need to get the newer cluster housing. The '90 and '91 housings are round instead of flat. And the wiring takes a while if you have an old 2g.
http://www.geocities.com/da6poweredef/EFinterior.jpg
dchatch
Feb 26, 2008 05:55 PM
v8Buster
Jan 20, 2007 08:16 PM
TheBestCRX
18
Apr 8, 2006 10:01 AM
jdmspec1122
13
Mar 21, 2004 12:49 AM
Fabrik8
Nov 5, 2002 08:19 PM
