97 in a 94 possible?
Old Jul 10, 2015 | 04:43 AM
tjmaxxwell's Avatar
Icon2 97 in a 94 possible?
hey guys quick question, will a 97 gs motor swap into a 94 with no issues? the 94 has 300k miles and i have an gs with 138k that i could use if its just a simple swap in and out. thanks guys
Old Jul 10, 2015 | 05:10 AM
egsleepercivic's Avatar
Default Re: 97 in a 94 possible?
yes, plug and play
Old Jul 10, 2015 | 05:12 AM
tjmaxxwell's Avatar
OBD1 to OBD2 wont matter? and i dont know if the 94 was a gsr or a non-vtec model but that wouldnt matter much would it?
Old Jul 10, 2015 | 08:55 AM
the plugs at the shock tower didn't change afaik, you can also plug and play the same swap into a 92-95 civic.
if the 94 was a gsr you will just have extra wires left
use the harness from the 97, it SHOULD plug into the 94, this will let you use the dizzy alt and injectors from the 97
Old Jul 10, 2015 | 05:19 PM
B_Swapped93's Avatar
alternator/injector clips and distributor, that's it really just keep those from your obd1 integra.
drummerdude
Aug 6, 2012 01:51 PM
DomesticIKiller
Oct 24, 2009 07:11 AM
steadyeddy
Jan 22, 2008 06:42 PM
Halo
Feb 12, 2003 12:59 PM
