Brake Conversion for 00 Civic Dx
Old Jul 8, 2015 | 06:15 PM
ColombianEk9Boy's Avatar
Icon7 Brake Conversion for 00 Civic Dx
I have a question regarding for 2000 Civic Hatchback on suspension.
If I wanted to go from stock drum 4x100 lug brakes to GSR 4x100 or Dc2 96-97 Disk brakes would it fit right with the current upgrades that I have for my current setup?
I have UCA's, LCA's, Buddy Club Coilovers, Rear Camber, and Subframe etc.. will they fit the brake conversion? Or will I have to get parts to fit the brake conversion?...
Many Thanks
Old Jul 8, 2015 | 07:23 PM
Chefskinny's Avatar
Default Re: Brake Conversion for 00 Civic Dx
yup. won't matter. You will need ebrake lines though
Old Jul 8, 2015 | 07:54 PM
FeelTheBass's Avatar
The rear's will bolt right up, complete plug and play except for the ebrake cables which you can swap from a 99-00 civic SI.
I'm pretty sure the front disc brakes will not fit with the integra hub, you have to acquire 96-00 civic EX hub/knuckles and bolt on the integra caliper/mounting bracket for everything to work.
The 96-00 civic ex and 94-01 integra both use a 10.3" front rotor so there's no problem there, but the integra caliper is slightly larger than the EX one if you prefer more stopping power.
Old Jul 8, 2015 | 08:01 PM
tony_2018's Avatar
Fish Twig
It will all bolt up. Functionality will depend on your handy work to reconnect everything else properly.
Old Jul 8, 2015 | 10:11 PM
98civdx's Avatar
Master Detailer
As stated, all of your current parts will bolt right right back up.
You will however need E brake lines, and the brake lines.
Old Jul 10, 2015 | 05:58 AM
Thanks guys so much for useful information! This is a big relief knowing that..
Now would it be better if I get the whole disk brake conversion for front and rear or can I keep my front brakes, (upgrade them aftermarket wise) and just convert the rear from drum to disk?
Thanks again
Old Jul 10, 2015 | 02:40 PM
98civdx's Avatar
Master Detailer
I would convert the front also, but that's just me. All depends on your needs/wants and what you can afford.
98dxhatchbuild
Sep 23, 2017 02:29 PM
Arthas
Mar 15, 2011 01:18 PM
hondapimpin420
Feb 2, 2009 11:47 AM
civicturbo22
Dec 2, 2004 09:00 AM
DaKINE-Ek
Mar 1, 2004 07:45 AM
