How do you bevel your exhaust runner tubes?
Old Jul 8, 2015 | 05:28 AM
1sick4g63's Avatar
Default How do you bevel your exhaust runner tubes?
Working on a manifold and tried using a flap wheel to bevel and it takes forever.
Anyone have a better and faster way with more consistent results to bevel the sch10 pipes?
Old Jul 8, 2015 | 07:40 AM
CODE4's Avatar
Default Re: How do you bevel your exhaust runner tubes?
What grit are you using? I use 36 grit 3M flap wheels all the time on sch 40 and sch 80 pipe and it makes metal go away right-the-****-now.
Using a fine grit only serves to polish.
Old Jul 8, 2015 | 10:47 AM
1sick4g63's Avatar
I believe it was a 60 grit. Also on the shorter pieces (straight sections that I cut) the get so hot so fast I have to put them down and let them cool for awhile before I get back to it.
Old Jul 8, 2015 | 10:59 AM
that-guy's Avatar
as CODE4 said, use a more coarse grit...the more time this disc is on the material, the longer it is causing friction and soaking heat into the material...and let the disc do the work, do go throwing your weight into it and applying a ton of pressure
Old Aug 1, 2015 | 12:15 AM
vtec_lude's Avatar
I use a 36grit ceramic belt on my belt sander and it takes about 10 secs to bevel each end.
Old Aug 12, 2015 | 06:16 AM
98vtec's Avatar
moderator emeritus
same here but I use 60grit
efHondefender
Welding / Fabrication
17
Mar 7, 2014 09:37 PM
b16bri
Mar 2, 2011 12:24 PM
Justin Olson
32
Jul 7, 2008 11:18 AM
DESTROYER
14
Sep 16, 2007 06:34 PM
Tigfab
Aug 21, 2006 05:17 AM
