1999 Honda Civic LX making an odd quacking noise in the rear
My civic makes a quacking noise while im applying the brakes and vehicle weight shifts. A quack that sounds just a duck. What could this be?
A duck. let it out of the trunk....
It could be bushings, struts, brakes...a duck...but really, you need to do some inspection to get an idea of what might be worn/failing/loose.
Try pushing down on the rear end while the car is stationary, if it makes the same noise, try to locate the direct source while someone pushes for you.
This post made me laugh because my civic makes the exact same noise.
Probably a worn bushing or maybe your struts.
Definitely get someone to push the back end up and down while you inspect for the source of the noise.
pityocamptes
Apr 13, 2016 03:25 PM
thecivicsi
Nov 19, 2014 12:37 PM
