94 del sol AC issue
1994 del sol Si manual
175,000
system leak found at high side tube and replaced
replaced compressor and drier at same time (AC used to only cool at higher RPM, not at idle)
28.5" Hg for 2 hours; added 134A (~18 oz)
Clutch comes on when pressing AC button
At ambient temp of 80 deg F and engine off: low and high @ 95 psi
engine at idle (800 rpm) and clutch on: 25 psi low, 170 psi hi
5 minutes after engine turned off, 50 psi low, 130 psi hi
it takes over an hour for the the pressures to equilibrate to 95 psi
center vent temp drops from 80 degF to 70 deg F
The clutch is not cycling on and off, it comes on and stays on.
High side tube gets very hot to touch; low side is cool but not cold and no condensation.
What else should I be checking?
175,000
Thanks for the info Ron.
A friend suggested that I increase the RPM to 3000 RPM.
idle: 20 psi low/ 170 psi high
3000 rpm: 12 psi low/ 270 psi high
Incidentally, the vent temp dropped from 70F to 55F when increasing RPM.
Creating a vacuum on the low side and increasing pressure on the high side
indicate a restriction according to my friend. Most likely candidates are condenser, evaporator or expansion valve.
Splashing water on condenser did not effect high side pressure. My friend
suggests that this means the condenser is not where the restriction is. Best
guess is either expansion valve and/or evaporator.
1trickpony
41
Jul 23, 2016 04:59 PM
xlasianizelx
Aug 24, 2010 01:27 PM
ncsolguy
Aug 25, 2007 06:32 AM
