b16a2 build
Hey guys and girls,
just looking for a bit of advice, i'm currently working on my rebuild I have most of what I need but wanted to know if theres anything you lot would recommend or anything I have missed!
so I have...
Skunk2 springs and retainers, rods, valves, stem seals and inlet
CP 11:1 pistons
Full gasket kit with genuine Honda head gasket
APR head studs
ACL Race Series con-rod bearings
ACL Race main crankshaft bearings
ACL thrust washers
Gates racing timing belt
Genuine Honda Water pump
Koyo timing belt tensioner
Genuine Honda oil pump
LSD box
Exedy stage 1 organic clutch
Fidanza ultralight flywheel
What would you guys recommend for ECU, cam gears, fuel rails, rads, exhaust systems, injectors, throttle bodies and possibly anything else I may be missing.
I'm trying to break 200hp, so any input would be awesome!!
so I have...
CP 11:1 pistons
APR head studs
ACL thrust washers
LSD box
