ball joint spins when I try to take it off
Old Jul 6, 2015 | 03:30 PM
Travlash's Avatar
Default ball joint spins when I try to take it off
I have a 98 ex coupe , d16y8. The tranny went so I am in the process of changing it . I am currently stuck on the passenger side axle. The ball joint spins when I try to take it off. I have tried about everything and it still doesn't budge . Can I take off the Lower control arm to temove the axle? Will that give the axle enough clearance to take it out of the wheel hub?
Old Jul 6, 2015 | 03:47 PM
Former User's Avatar
Default Re: ball joint spins when I try to take it off
Try securing top of ball joint with a c-clamp.
Old Jul 6, 2015 | 03:53 PM
NotARaCist's Avatar
I never narc'd on nobody!
Mine do that, too. What I do is to wedge a pickle fork in there, and turn the wrench while I hit the pickle fork with a hammer.
Old Jul 6, 2015 | 04:00 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Large needle nose vice grips. Carefully move the boot out of the way enough to grab the UN THREADED stud with the vice grips.
Player.
Old Jul 6, 2015 | 04:10 PM
Travlash's Avatar
And if none of this works ? Can I unbolt the lower control arm to move the wheel Hub ?
Old Jul 6, 2015 | 04:29 PM
B serious's Avatar
I believe you can do anything you put your mind to
Old Jul 6, 2015 | 04:39 PM
brenton.wood's Avatar
When I replaced mine in the CRX, I took my pickl;e for and hammered it in there and was able to get it tight enough to remove the nut
Old Jul 6, 2015 | 06:53 PM
Hondaciv866's Avatar
op this is most likely happening because the threads on your ball joint are damanged. Next time you take you "pop" the lower ball joint off do not take the nut all the way off. If you do remove the nut, when the joint is poped loose it will cause metal to shear on the threads. If you keep the nut on, the nut will "catch" the metal and prevent thread damange..
when i had this problem i ended up leaning my pry bar againts the lower ball joint (against the boot) and using a 4foot metal pipe on the end of the pry bar to putt alot of pressure againts the joint to stop the spin. hard to explain
Old Jul 6, 2015 | 08:00 PM
^Very odd response.
Try one or all the suggested methods and then post if none works.
Old Jul 7, 2015 | 07:26 AM
KPDSM's Avatar
Player.
Has worked the last 3 times the it spun on me...
Old Jul 7, 2015 | 09:47 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Originally Posted by RonJ@HT
^Very odd response.
I believe this is a planning for the worst while hoping for the best. The worst of course being none of the current suggestions work.
The power in this approach is hopefully reducing the amount of back and forth to the PC/Internet.
Oh and not saying that the suggestion won't work, just making an observance to the behavior. I really don't foresee all the current suggestions failing.
Old Jul 8, 2015 | 08:13 AM
MadVladCivic's Avatar
Yes, it will work. I had the same dilemma although I simply could
not separate the ball joint. Pounding on the knuckle w/ a BFH
seemed pointless after awhile so I attacked from the direction you
noted. Four large (19mm socket) bolts on the underbelly.
Remember to point the wheels straight ahead if you turned them
in order to access any bolts. Otherwise, when you go to place the
new axle, the geometry will be off and you will have much aggravation.
Old Jul 8, 2015 | 09:33 AM
98civdx's Avatar
Master Detailer
have someone step on the caliper and Push down, you knock the nut free.
B serious's Avatar
...why would the geometry be off if the wheels are turned while removing the LCA?
Old Jul 8, 2015 | 09:56 AM
98civdx's Avatar
Master Detailer
^I laughed a little when I saw that too.
Old Jul 8, 2015 | 03:02 PM
tamboo's Avatar
10 Year Member
BruceLee5000
15
Mar 7, 2017 04:34 AM
jmvtec05
Honda Civic (2001 - 2005)
Aug 11, 2012 09:25 PM
w0ng_sta
Jan 3, 2007 07:05 PM
VisualAutoMotoring
Oct 11, 2003 04:08 PM
kilabeez
Sep 18, 2001 06:58 AM
