B16 turbo hondata base map help
Old Jul 5, 2015 | 04:17 PM
Mjalaly's Avatar
Default B16 turbo hondata base map help
I am looking to see if someone might have a base map or be able to offer any help to get my car runnung right to get it to my tunner (which is 30mi away). I tried running a stock map , changing the injector size and map sensor but it s bogging and trying to stall when i give it gas. I pulled the injectors and they were black, super rich. Any thoughts or does some one have a base map that can try? Maybe altitude is the issue (5280ft)?
Build
B16a
gt32 turbo
rc 650cc injectors
3 bar map
spooling log mani
tail f38 wastegate
Cant figure out how to post my map
Old Jul 5, 2015 | 04:56 PM
91b18a1ls's Avatar
Default Re: B16 turbo hondata base map help
Did you put the correct injector dead times in? and the correct map sensor scaling? And really this should be in the tuning section. You'd get more help there. Your tuner should be able to make one for you and send it over
Old Jul 5, 2015 | 05:16 PM
Mjalaly's Avatar
Originally Posted by 91b18a1ls
Did you put the correct injector dead times in? and the correct map sensor scaling? And really this should be in the tuning section. You'd get more helvp there. Your tuner should be able to make one for you and send it over
The map scaling is right. For the injectors all i did was input 650 in the current injector size area under the fuel trim tab.
How do i move the thread?
My tunner islooking for something. They are closed until tuesday.
Should i switch to closed loop-stock sensor??
Old Jul 5, 2015 | 09:59 PM
wantboost's Avatar
Who is Mr Robot?
I can move it for you
Old Jul 6, 2015 | 04:57 AM
Mjalaly's Avatar
cool thanks
Old Jul 6, 2015 | 04:58 AM
Mjalaly's Avatar
Any one else have any suggestions on what to do or have a base map i can try??
Old Jul 7, 2015 | 09:25 AM
HAMOTORSPORTS's Avatar
RC injectors will typically need another 10-15% more fuel added in the "overall fuel trim" area to run correctly. Also be sure you've entered the injector dead time/latency for your injectors.
If your map sensor settings are off it will run poorly, if at all.
EFjoe91
Oct 6, 2012 11:28 AM
b20turbocivic
Engine Management and Tuning
14
Dec 28, 2009 11:31 AM
JDM97R
Jul 22, 2008 09:27 PM
irocdaparty85
Jul 25, 2005 09:23 AM
01ITR#700
Jun 19, 2003 02:20 PM
