Gsr blinking check engine light
Old Jul 4, 2015 | 04:57 AM
98dxkoupe's Avatar
Default Gsr blinking check engine light
Was driving home this morning and noticed my check engine light came on then started blinking which was weird. Car has 176k and does run a little ric , black soot on the rear bumper im going to go see what the code is anyone had this happen to them before?
Old Jul 4, 2015 | 10:56 AM
tamboo's Avatar
10 Year Member
Default Re: Gsr blinking check engine light
try the diy area sometime, you can learn a lot.
https://honda-tech.com/acura-integra...s-here-978933/
Old Jul 4, 2015 | 11:08 AM
thewrai6th's Avatar
When it's blinking, your engine is currently misfiring for any number of reasons. It should probably throw you into limp mode as well. Stop driving like that and check the fault codes.
Old Jul 4, 2015 | 12:00 PM
98dxkoupe's Avatar
Update went to advance auto to get the code read but there was no check engine light and no code!! And nothing stored at all. Now the light only comes on and goes off im kinda stumped would a clogged fuel filter throw a code?
Old Jul 4, 2015 | 12:05 PM
tamboo's Avatar
10 Year Member
if it comes on again leave the engine running and pull the code.
Old Jul 5, 2015 | 03:32 AM
HondaPartsHero's Avatar
Technical Hero
Year make model?
Old Jul 5, 2015 | 04:09 AM
98dxkoupe's Avatar
2001 integra gsr
Originally Posted by HondaPartsHero
Year make model?
Old Jul 5, 2015 | 04:52 AM
m90polk1's Avatar
Blinking check engine light while driving =misfire, keep driving on it and if you have a catalytic converter all the unburned fuel will destroy that. Also you may notice terrible gas mileage and very sluggish performance. So if your able to pull the cel with the car running do that otherwise check your ignition system, I know the distributor houses 2 or 3 sensors that control ignition. You should be able to trouble shoot it yourself as Honda made it very easy to do that for most of their cars.
Old Jul 5, 2015 | 05:00 AM
98dxkoupe's Avatar
Thats what i thought it was misfire but for some reason the code is not there. I will try to trouble shoot myself i will have to do my research i am not sure how to trouble shoot the distributor.
Old Jul 5, 2015 | 10:00 AM
tamboo's Avatar
10 Year Member
might want to do a valve adjust if it hasnt been done lately.
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Old Jul 5, 2015 | 11:44 PM
98dxkoupe's Avatar
That link doesn't work.
Old Jul 6, 2015 | 12:37 AM
98dxkoupe's Avatar
Car was recently purchased back in January so i highly doubt valves have been adjusted. We will see if this code shows up this week.
Old Jul 6, 2015 | 08:53 AM
guyver13's Avatar
check that your fuel injectors are properly plugged in and didnt come loose and/or are working properly.
Old Jul 6, 2015 | 10:27 AM
tamboo's Avatar
10 Year Member
link works for me.*shrugs* try this:
https://honda-tech.com/honda-civic-d...odule-1430824/
Old Jul 6, 2015 | 01:10 PM
98dxkoupe's Avatar
Just pulled the code misfire in cylinder 1 wtf im gonna try an inspect my fuel injectors. Would a bad fuel filter cause this?
Old Jul 6, 2015 | 05:49 PM
thewrai6th's Avatar
So many things can cause that, from spark plug/dizzy, to vacuum leak, to fuel pressure/injectors, even a bad engine coolant temp sensor (my latest) or bad tank of gas. Blown head gasket, burnt rings, cracked pistons... the bad list goes on...
Timing belt done recently? Could be the crankshaft sensor came lose, which is the sensor that is setting that code.
If you're lucky, it will either go away on its own, or eventually throw a code for what is causing the misfire.
Light or heavy throttle when it blinks?
Old Jul 7, 2015 | 12:20 AM
98dxkoupe's Avatar
He thing is the light hasnt blinked at all but i also haven't been giving it heavy acceleration. Wow that's alot that could go wrong i do think timing belt was replaced the car has 176k looks like im gonna be looking to get a rebuild in the near future
Old Jul 7, 2015 | 12:34 AM
98dxkoupe's Avatar
When the light did blink it was under heavy acceleration
Old Jul 7, 2015 | 01:46 AM
98dxkoupe's Avatar
Update on the way to work this am the engine code went away some im thinkinh the problem is intermittent?
Old Jul 7, 2015 | 03:34 PM
thewrai6th's Avatar
Bad gas is possible, or it only happens under high load/rpm.
Old Jul 7, 2015 | 04:13 PM
98dxkoupe's Avatar
I'm going to try changing spark plug wires an gonna check an see if spark plugs are in good condition. Any advice to solve this problem?
Old Jul 7, 2015 | 05:59 PM
thewrai6th's Avatar
First, you would have to be able to reproduce the problem... A leakdown test is a good place to start.
Old Oct 2, 2018 | 04:32 PM
James Reed's Avatar
Sorry to revive this thread but I’m having a issue so here goes the specifics.
i have a 2000 gsr and just recently the check engine light started flashing 8x total while the key is in the on position but the car is not running. When I start the car I get no codes and the car runs and drives fine. I checked the plugs wires and cap and rotor and there all good only thing I have not checked as of yet is the ignition coil. So I’m stumped any help would be nice. Please and thank you
67tj67
Oct 4, 2018 11:38 AM
importdude2000
Jul 17, 2004 12:53 PM
UpstateCivic
Jun 7, 2003 12:27 PM
eg686
Apr 18, 2003 01:01 PM
