95 Civic/B16a3 swap - cranks but wont start
Old Jul 3, 2015 | 09:08 AM
big_jay239b16A's Avatar
Default 95 Civic/B16a3 swap - cranks but wont start
I have a 95 Honda civic with a B16a from a 1994 Del sol. I recently reserfaced the head, put ARP heard studs, new head gasket, new timing belt and water pump. also new valve cover gasket. For fome reason my car just basicly just died out. once I pulled over I went to start it and it would just crank and not turn over any sugestion?
Old Jul 3, 2015 | 09:35 AM
cafrog's Avatar
Default re: 95 Civic/B16a3 swap - cranks but wont start
I have to guess that you did these changes and things were fine but then things went bad all of the sudden . Right??
Check All Fuses.
Check All Grounds.
Do you hear fuel pump prime when putting key to "on" position?
Check mechanical timing (maybe jumped a tooth)
Old Jul 3, 2015 | 09:41 AM
ok ill let you know later today when i get back to it
Old Jul 3, 2015 | 11:42 AM
Former User's Avatar
Default Re: 95 Civic/B16a3 swap - cranks but wont start
Also check for spark and CEL codes.
RookieCivic
May 31, 2013 03:38 PM
KnotInMud12
Mar 21, 2012 06:09 AM
TigerLy
Jan 1, 2012 07:29 PM
DumpdEJ6
21
May 25, 2011 11:31 AM
eg2GAMEOVER
Feb 22, 2009 03:41 PM
