Low compression
Old Jul 2, 2015 | 10:55 AM
jason_SIR's Avatar
Default Low compression
Low compression on one cylinder 170 170 170 and 60 on #4 also have some small sings of oil in the colent thinking its the head gasket or should I be worried about something else ?
Old Jul 2, 2015 | 06:00 PM
Tachi's Avatar
Default Re: Low compression
You have 30% of the compression in one cylinder as the rest and oil in the coolant. Either your head gasket is toast or your oil cooler and a valve both went at the same time, and you know occham's razor...
Old Jul 2, 2015 | 09:31 PM
holmesnmanny's Avatar
Did your car overheat at some point ?
Old Jul 3, 2015 | 06:59 AM
Tachi's Avatar
I was going to ask that but it seemed like something that would be too important not to include. OP, if your car did overheat or runs warmer than it should, pop off the radiator cap and let it idle. If you see bubbles or air in the coolant, you have your answer.
Old Jul 3, 2015 | 06:36 PM
jason_SIR's Avatar
Iv had the car for a Lil over a year dosent run hot runs great under my ounership hasn't over heated
Old Jul 3, 2015 | 06:37 PM
jason_SIR's Avatar
If I see air commin out the rad would that mean head gasket
Old Jul 3, 2015 | 06:51 PM
Tachi's Avatar
It would mean combustion gases getting into the water jacket. Usually accompanied by lots of white smoke (steam) coming from the tailpipe on startup.
Old Jul 6, 2015 | 07:57 PM
4imports.net's Avatar
I would definitely consider the head gasket. But I would also check the valve lash to be sure the valves aren't too tight not allowing valve to close all the way
Old Jul 7, 2015 | 05:04 AM
Tachi's Avatar
I would give creedance to this theory as all of my intake valves were a little tight and my compression went up twenty pounds in each cylinder, but for there to be such a huge discrepancy in compression would have to mean either a bungled valve adjustment or there is a dangerously loose adjustment nut on that rocker arm. It would also not explain the oil in the coolant.
bvillarreal
Aug 22, 2013 09:43 PM
Nicolai
Jun 16, 2013 03:38 PM
lyzer227
Mar 27, 2008 08:27 PM
F Bomb
Jan 31, 2008 06:39 PM
InTeGrA B18b1
Mar 20, 2005 03:18 PM
