boost guage question
Old Jul 1, 2015 | 08:50 AM
h9civic3's Avatar
Default boost guage question
I have a 93 civic with D15B VTEC with JRSC. I have not got it tuned yet but I have a question about the boost guage. When the car is off, the guage reads about 4psi boost. When the car is sitting idle, the guage reads about 10 psi vacuum. If I accellerate, the guage will read 6 psi boost. However, I have seen it go up to about 12 psi boost. Mind you it is only a 6lb pulley.
Does this sound like a bad guage, slipping belt, etc?
Also, what are my idle readings supposed to be on the guage?
Any help is appreciated. Thanks.
Old Jul 1, 2015 | 12:24 PM
KevinEF7's Avatar
Default Re: boost guage question
Your gauge is simply out of wack and not sitting the needle in the correct position, time for a new one unless your brave enough to open it up and set it to zero
At idle you will typically read -18 to -22
Old Jul 1, 2015 | 12:31 PM
supersilverdc2's Avatar
X2
You should have no vacuum when car is not running
Old Jul 1, 2015 | 04:29 PM
wantboost's Avatar
Who is Mr Robot?
You've just discovered the inherent problem with all mechanical air core gauges...
Old Jul 2, 2015 | 03:47 AM
h9civic3's Avatar
Ok cool. Is it that much of a chore to open up the guage and reset the needle? Will it still be accurate?
Old Jul 2, 2015 | 07:04 AM
TheShodan's Avatar
Moderator
yes. it would. just get another gauge in this case.. from a different company and be done.
ZCcivic91
Sep 9, 2007 07:26 PM
DriveSlowHomie
Sep 28, 2005 09:22 AM
ash.zero
Jul 9, 2005 04:22 PM
InTeGrA B18b1
Jun 2, 2003 03:26 PM
zdr262
Sep 25, 2002 01:38 PM
