Rough idle can't drive over 20mph
Old Jun 29, 2015 | 08:16 AM
jlw1964's Avatar
Default Rough idle can't drive over 20mph
At first when driving it felt like the vtec oil sensor letting me know check oil.But it was full so i went ahead and changed oil/filter.Still the same result,when in park and trying to increase the rpm's it won't go past 2000 it flutters,,sounds like a knock.Any ideas or suggestions?
Old Jun 29, 2015 | 10:36 AM
holmesnmanny's Avatar
Default Re: Rough idle can't drive over 20mph
Check for any stored codes.
Old Jun 29, 2015 | 10:54 AM
jlw1964's Avatar
Old Jun 29, 2015 | 10:55 AM
jlw1964's Avatar
P1491
Old Jun 29, 2015 | 11:02 AM
jlw1964's Avatar
I checked vacuum hoses have fuel rail off cleaned out have egr off cleaned
Old Jun 29, 2015 | 12:22 PM
You might want to check your mechanical timing. That egr code shouldnt cause your car to redline at 2000.
Old Jun 29, 2015 | 12:46 PM
jlw1964's Avatar
How could it just jump out of time while just driving?
Old Jun 29, 2015 | 02:35 PM
MAD_MIKE's Avatar
MM Gruppe B
Stranger things have happened.
Verify general engine health.
Crackpot guess.
PCM is expecting a given amount of EGR valve lift at a given rpm under various conditions, but due to lack of vacuum the valve is not opening. Combined with the limted RPM range, I'll go with a restriction in the exhaust.
Check your muffler for any
Old Jun 29, 2015 | 06:03 PM
lol mike I use the "banana in the tailpipe gag" expression when I play jokes on my buddies.
I agree with mike, it's possible you could have a restriction as well. To test, you can remove the front oxygen sensor from the exhaust to allow possible restricted exhaust gas a way to exit. If the car runs better then you know what the cause is.
Old Jun 30, 2015 | 07:53 AM
jlw1964's Avatar
Car will not hardly start and stay runnning at this point.Was running perfeclty until previous issues started.At the beginning it acted like the vtec oil pressure sensor was acting like low on oil.Not the case,then it sat for a week did'nt have time during the week to work on it.So a week later it does'nt want to start and if it does it wont idle and stops running immediately.So i took egr of fuel off cleaned fuel injectors fuel egr and ports same result.
Old Jun 30, 2015 | 07:56 AM
jlw1964's Avatar
Next step is disconnect O2 then catalytic converter to see if there is restrictions in the exhaust flow.Any other ideas?
Old Jun 30, 2015 | 01:02 PM
jlw1964's Avatar
Problem solved catalytic converter plugged.
Old Jun 30, 2015 | 03:03 PM
Another happy customer mike
Old Jun 30, 2015 | 06:25 PM
jlw1964's Avatar
Great advice!
Old Jun 30, 2015 | 07:21 PM
MAD_MIKE's Avatar
MM Gruppe B
^5
Now, if we could figure out how the hell to get paid for this
Old Jul 3, 2015 | 04:16 AM
Lost Again's Avatar
Originally Posted by MAD_MIKE
^5
Your payment is you get to post for free
Old Jul 4, 2015 | 10:31 PM
MAD_MIKE's Avatar
MM Gruppe B
*looks at phone bill*
Nope, internet is still not free.
Old Jul 8, 2015 | 04:36 PM
Lost Again's Avatar
But your membership here is free
SeanD13
Jan 26, 2015 07:21 PM
EGgarniEG
Nov 15, 2007 06:00 PM
pinoyboy204
Oct 5, 2003 08:12 PM
russian_racer
Jun 28, 2003 02:01 PM
CivicSiR7
Jan 17, 2003 08:42 AM
