looking for some info on how to wire tuck the harness that run along the sides of the car inside the cab to the rear.
In this integra it looks very clean and I am not sure if this is a custom harness , or if it was tucked some how. looking for help. Currently prepping for paint.
Passenger side is ABS only, I will remove that....
as for the driver side it has the wiring for the rear lights. is there a way to run it through the runner below the door, behind where the side skirt mounts? does it require cut and extension of wiring?
Im in the same process but im jus thinkn of different ways to make it look nice.. Ill be removing my abs unit also
Sweet man!
The front floor boards were a pain in the *** for me, but all the other stuff was ok with the dry ice.... I found a brass wire wheel that would fit on my drill for the rest of the glue crap, then I wiped with professional grade goo gone.
Then I sprayed primer to fill in any scratches... Then scratched with a red scotch price pad. I'm just waiting on my paint guy at the moment.....
What color you going with?
I think I may just look for some type of black foam wrap for the wire or tape it with electrical tape all the way back.... The wire tuck may be more trouble than what it's worth.
On my new build i'm only going to be left with the brake lights/fuel stuff honestly if you want just remove as much as possible, i'm assuming you will put the interior back tho?. next thing painting wise just rip it all up and stuff it in the dash or what remains of the dash support bars, is your dash still in place. That wiring/loom is a lot tougher then most ppl think
Yea, I actually contacted rywire and they said it was a pain and not something that they would like to do again, but if the price is right.... I may end up tucking in the dash for paint, then putting that snake mesh over to make it look clean.
Dash is in place, I'll just plastic cover it and have him paint all the way up under where pedals are and be done. As far as interior goes. I will have door and side panels. No rear panels and will keep the roof panel as well. Not putting carpet back in... Going for clean paint look
