93 Civic fuel pressure issue
Old Jun 25, 2015 | 07:49 AM
PatrickoIreland's Avatar
Default 93 Civic fuel pressure issue
I need help. I try to start it and a lot of times I am not getting fuel. Then, only sometimes, I release the pressure from the gas cap, turn the key (before cranking it) and hear a brief high pitched vacuum sucking noise from the engine area. Any ideas?
Old Jun 25, 2015 | 10:20 AM
egsleepercivic's Avatar
Default Re: 93 Civic fuel pressure issue
when it doesn't prime are you getting power to the pump ?
usually the check engine light comes on and then turns off once the pump primes
instead of taking the cap off next time try tapping the main relay under the dash and see if it starts
Old Jun 25, 2015 | 12:00 PM
I'll try it. I replaced the main relay a few weeks ago and that's when I first heard the vacuum sucking noise.
Broke_not_built
Aug 22, 2011 10:40 AM
Jarod725
Mar 31, 2008 02:24 PM
Orangecivic251
Jan 23, 2007 06:52 PM
B18Cej1
12
Nov 8, 2005 05:05 AM
Jonmon
Jun 17, 2005 03:41 PM
