1993 honda eg si hatch h22 swap HELP!!!
Old Jun 24, 2015 | 11:57 AM
Freshmodsegh22's Avatar
Default 1993 honda eg si hatch h22 swap HELP!!!
Hello everyone. I got a eg hatch with a h22a in it everything his hooked up but here's my issue, I tryed starting the car the starter and alternator is working fine. But then I was getting no spark from my dizzy. So I then replaced the dizzy with a new one. And after I installed it. It started then shut off. I tryed starting it again and nothing happened. As of right now I got the original p28 obd1 that I used to start the car. And I got the obd2 p13. Could that be the reason why it's not starting because the p28 is throwing everything off such as timing and injectors. Please help I'm stuck on this one. Thanks
Old Jun 24, 2015 | 03:11 PM
v4lu3s's Avatar
RTFM
Default Re: 1993 honda eg si hatch h22 swap HELP!!!
it should start an almost every honda ecu that you can plug in. i have started h22's and let them idle on pt2, p13, p06, p28, p72 and other ecus.
You need to probably check all your wiring again.
Old Jun 24, 2015 | 03:28 PM
I checked the wiring, every thing looked fine. it's sounds like it wants to start l. Im going to check the injectors.
Old Jun 24, 2015 | 05:19 PM
v4lu3s's Avatar
RTFM
check usually means continuity as well rather than just looking.
Old Jun 24, 2015 | 06:14 PM
Yea I made sure all the plugs and grounds were all in its proper locations. And made sure they were all secured.
Freshmodsegh22
Jul 12, 2015 10:29 AM
jdmept
Mar 27, 2013 07:15 PM
hatchback13sec
Nov 13, 2008 10:06 AM
bambbrose
Jul 8, 2007 10:00 PM
KNIVES
Apr 7, 2004 05:24 PM
