F22B2 fully building new head, suggestions?
Just got a new Rebuilt head from a guy from ebay who sells them for 215$ after shipping. I want to fully build this head when the head is done I'll purchase the block and build that but that will be another thread.
I have a few questions before those questions my goal for this build is nothing under 225 HP if I could get 225 HP or a little over would be perfect as this will be a daily driven car that has just the right amount of go when I need it.
1. Stainless steel or titanium valves in terms of price will the titanium really do that much better?
2. Delta regrind or Bisimoto Regrind in terms of price whats the best bang for my buck for the power I'm trying to achieve?
3. Is it worth having the head ported for the amount of power it will get as I want to achieve around 225 HP.
4. Upgraded valve springs & Retainers (Titanium?) would it be worth the investment.
My main goal is not to waste money on useless parts I'm a novice just getting started I need all the advice I can get, If you can recommended exactly which parts I would need to achieve this goal that would be great.
I was staying all Honda on this build but I don't know if the head parts are interchangeable for more power & the amount I'm trying to achieve.
It won't happen on a B2 head, unfortunately, and you pretty much just wasted $215. They just don't flow well enough. Not only that, you won't have the compression to support the camshaft profile that will be needed, as well as the other supporting modifications. You CAN make that kind of power with an H22(very easily) or an H23A VTEC(moar torkz!), and that kind of power has been made on F23 block/F22A head combos. It SHOULD be possible to make that kind of power with a straight up VTEC F23 considering the flow/velocity numbers, but no one seems to want to attempt it and just does the F22A heads because of the superior port and valve geometry, as well as much better supported valvetrain components and camshafts. You'd be pretty surprised at how well a VTEC F23 does with some minor bolt ons, tuned, and mated to a better geared H-series transmission. My car isn't much slower than near-stock H22 Preludes, and it's basically a '97 LX Coupe with an F23 swap, stock ECU, header, 3" intake, stock exhaust piping into an RSX-S muffler, and 94-95 wagon transmission. A tune, porting the F23 intake, a real exhaust, better header, and H-series transmission would make this thing a REALLY lively car; it's also my DD. See my build thread in my signature for more info on it.
Here's a VERY good thread you'll learn lots of information from:
jdm92_accorn : 1992 Accord LX - CB7Tuner Forums
I recommend reading through that before you make any more purchases.
Good head flow, good cam, rods and high comp pistons will get you to were you want to go! It can be done cheaper, however something I always like to remind people.
Fast and Cheap = Not reliable!
Fast and Reliable = Not cheap!
Cheap and Reliable = Not fast!
b20vtec214
12
Dec 25, 2005 06:23 PM
