Jackson Racing Crank Pulley (How does it benefit?)
Old Jun 20, 2015 | 08:53 AM
qhiggy's Avatar
Default Jackson Racing Crank Pulley (How does it benefit?)
So I have am installing my JRSC. I have a jackson racing crank pulley. I was just curious what the benefit of one is? Is it something I need installed? I am installing it either way, I already have my crank pulley. I do have plans of bumping up to the 8 psi pulley. I have a buddy who is going to help me chip an ECU and tune it. Getting rid of the fmu and map controller. Any information is appreciated. Thanks!
Old Jun 20, 2015 | 09:09 AM
qhiggy's Avatar
Default Re: Jackson Racing Crank Pulley (How does it benefit?)
This is the crank pulley I have.
Old Jun 20, 2015 | 09:16 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It appears that you have a '96-00 Civic "D" series kit... which uses a 3-rib drive belt, and this is why the crank pulley is necessary. If you install it on a '92-95 civic, a 4 rib belt works just fine... and a stock style crank pulley works as well.
Replacement JR 3-rib blower pulleys are nearly impossible to find but 4 rib pulleys are available... but using them on an EK is tight.
Old Oct 5, 2015 | 09:41 PM
qhiggy's Avatar
I am reviving this post. I had to remove my stock crankshaft pulley to do a timing belt and get the water pump properly torqued - didn't have a small enough torque wrench before. Should I install the upgraded crank pulley? I read somewhere that it can damage my engine if I don't have it balanced for it. Is this true? Also, will it show any benefit at all when it comes to power? Thanks!
blown_mb2
Dec 9, 2012 10:45 AM
aziraco47
May 7, 2009 06:52 PM
j_wod2000
Mar 2, 2006 02:17 PM
kantfadedisazn
Jan 26, 2006 06:15 PM
JustinZC
Jan 2, 2005 06:15 AM
