Jackson Racing Crank Pulley (How does it benefit?)
Old 06-20-2015, 08:53 AM
Default Jackson Racing Crank Pulley (How does it benefit?)
So I have am installing my JRSC. I have a jackson racing crank pulley. I was just curious what the benefit of one is? Is it something I need installed? I am installing it either way, I already have my crank pulley. I do have plans of bumping up to the 8 psi pulley. I have a buddy who is going to help me chip an ECU and tune it. Getting rid of the fmu and map controller. Any information is appreciated. Thanks!
qhiggy is offline
Old 06-20-2015, 09:09 AM
Default Re: Jackson Racing Crank Pulley (How does it benefit?)
This is the crank pulley I have.
qhiggy is offline
Old 06-20-2015, 09:16 PM
It appears that you have a '96-00 Civic "D" series kit... which uses a 3-rib drive belt, and this is why the crank pulley is necessary. If you install it on a '92-95 civic, a 4 rib belt works just fine... and a stock style crank pulley works as well.
Replacement JR 3-rib blower pulleys are nearly impossible to find but 4 rib pulleys are available... but using them on an EK is tight.
JRCivic1 is offline
Old 10-05-2015, 09:41 PM
I am reviving this post. I had to remove my stock crankshaft pulley to do a timing belt and get the water pump properly torqued - didn't have a small enough torque wrench before. Should I install the upgraded crank pulley? I read somewhere that it can damage my engine if I don't have it balanced for it. Is this true? Also, will it show any benefit at all when it comes to power? Thanks!
qhiggy is offline
Too_slow_eg
05-11-2010 10:45 AM
jlfrnce
10-24-2009 07:07 PM
00cord
07-18-2007 07:40 AM
Full-Race Henry
11-04-2003 09:56 PM
Quick Reply: Jackson Racing Crank Pulley (How does it benefit?)
  • Ask a Question
Question Title:
Description:
