automatic civics with dohc
Old Nov 4, 2002 | 05:34 PM
importneeds's Avatar
Default automatic civics with dohc
has any1 messed with an automatic civic and put a dohc engine in it
Old Nov 4, 2002 | 05:45 PM
jdmb16ahybrid's Avatar
Default Re: automatic civics with dohc (importneeds)
that would be stupid! - why - learn to drive a 5sp...
Old Nov 4, 2002 | 06:11 PM
FortunateFool.'s Avatar
Default Re: automatic civics with dohc (jdmb16ahybrid)
well im not sure it can be done easily.
havent tried it myself, but thats how i ended up getting my b18b.
some guys tried to put it in an auto civic and it didnt work right, idle was all fucked up and stuff. but i just slapped a gsr tranny on it and swapped it in mine.
Old Nov 4, 2002 | 06:54 PM
TurboBumblBee's Avatar
ok whatever newb.. why the hell do you think honda made an integra ls?? cause its a dohc motor and its available in AUTO.. its more expensive to convert to 5spd and some people just may not feel comfortable driving 5spd.. my girl can drive 5spd but doesnt ever cause she just doesnt like it..
Old Nov 4, 2002 | 06:56 PM
jas0n's Avatar
Please don't hurt me!
Default Re: automatic civics with dohc (95CivicEX)
japan offers auto b16a's and b18c's (gsr)
Old Nov 4, 2002 | 07:16 PM
AutomaticB16's Avatar
An automatic B16 is possible. my 95 civic has an automatic b16 dohc which can only get from japan. unless you have money i would not recommend it. when you buy a motor it comes with all the goodie like alxes.ecu,shift linkage and tranny but it won't work. like on my civic, the 2 axles are 2 different year one del sol and other integra. the motor mounts are all different. the tranny mount you have to drill a hole on the existing mount the back mount is from an integra and the driver side mount is a del sol. now many people that i know said automatic sucks and go with manuel cuz its funnier but i never listen so i just got done building my bottom end of a high compression of 12.5 (which you have to use racing gas or retard your timing) an beating dohc cars with no problem. but if you do this swap. i recommend getting your torque converter mofidied at levelten.com which will help you take off the line like no thing. automatic is an advantage because you are more consiten and don't lost that split sec. cuz your shifting. other than that thats how it works. i recommend stick shift because my guy said that automatic swap was the hardest swap he have ever done.
Old Nov 4, 2002 | 07:20 PM
Dark Halo's Avatar
Default Re: automatic civics with dohc (AutomaticB16)
is it really worth it?
Old Nov 4, 2002 | 07:24 PM
Default Re: automatic civics with dohc (webbman44)
No its not worth it, but if you live in L.A. yes it is cuz freeways sucks!!!
Old Nov 4, 2002 | 09:09 PM
98akcivic's Avatar
I was think of swapping in a b18b automatic into my 98 coupe.
Old Nov 4, 2002 | 09:33 PM
hatchback's Avatar
it can be done, do what you want to do.
94Vtecluder
14
Jun 10, 2006 08:59 PM
Spins
May 27, 2004 07:23 PM
NicNitty
Jan 1, 2004 12:53 PM
cybspur
Sep 14, 2002 06:53 PM
VTECTIME
29
Aug 31, 2002 07:33 PM
