Piston ring orientation
the rings should be marked to know which direction to place them as far as up and down, aftermarket will tell you usually, factory you just follow the manual. for gap orientation just follow the manual.
The thrust surfaces are on the intake and exhaust sides of the piston/cylinder walls.... AKA load sides. They are 90° from the wrist pin sides. As indicated by the arrows in the image above. Make sure your ring gaps are in between those areas.....lol
averyvm
Apr 5, 2007 07:25 PM
