92 Civic VX - Odometer or VSS is not working after heavy rain
Old Jun 16, 2015 | 01:59 PM
StewieVX's Avatar
Default 92 Civic VX - Odometer or VSS is not working after heavy rain
Hello guys. I have an issue with odometer or Vss not working after heavy rains and sometimes on very wet humid days. After it dries up it starts working but we just had heavy rains and so far it's not working. Maybe it will come back.
Did anyone experience that before and is this vss or vss gear issue?
What is causing that or what should be replaced.
Old Jun 16, 2015 | 04:50 PM
Former User's Avatar
Default re: 92 Civic VX - Odometer or VSS is not working after heavy rain
Usually the VSS connector is corroded. Unplug it and inspect.
Old Jun 16, 2015 | 05:23 PM
StewieVX's Avatar
Thanks Ron. If connector corroded would spraying wd40 help or any idea how to remedy this?
Old Jun 16, 2015 | 05:51 PM
Inspect it. If it looks nasty, try cleaning the connector and pins. Otherwise, scout junk yards for connectors in good condition.
Old Jun 17, 2015 | 09:13 AM
StewieVX's Avatar
Ron thanks. I took a look at it just now and it's not corroded at all but even inside the plug inside it was wet a bit and cables were wet as well so i dried it up and it works again. I drove over standing water when it flash flooding here which is what got it wet. Little issue those Civic have is that there is not engine bay cover underneath the car so water snow etc gets in there which is why this issue came up. Thanks for help.
One day i may take it out as it's easy to get to and clean it out with brake cleaner to get the dirt out.
Old Jun 17, 2015 | 09:38 AM
Dry/clean the connector with brake cleaner and then moisture seal it with dielectric grease.
Old Jun 17, 2015 | 10:16 AM
StewieVX's Avatar
Awesome advice. I will do that. I also learned as my buddy has same car that VX does have under bay cover, it just someone on mine removed it. Why i have no idea. I'm also missing all wheel covers as well which is not as big deal as engine bay. I looked it i found it for $30 so i will get it. Crazy.
BTW the grease would go on outside of plug or inside or both?
Old Jun 17, 2015 | 10:41 AM
tony_2018's Avatar
Fish Twig
Di electric grease goes on the inside of the plug. There is nothing covering the section where the VSS is. There is a cover for the near the front of the car though, maybe that is what you are thinking of.
Old Jun 17, 2015 | 10:48 AM
StewieVX's Avatar
Tony thanks. I will get that done. I was referring to engine splash guard right under the car. Piece of plastic that prevents any water going inside engine bay. Most cars have it. My bud says he does too but mine doesn't have it so all water goes inside engine bay.
Old Jun 17, 2015 | 11:02 AM
tony_2018's Avatar
Fish Twig
Right but it doesn't cover the section where the vss is located, it only covers the front engine, mainly the belts.
Old Jun 17, 2015 | 11:42 AM
StewieVX's Avatar
Tony are we talking about 92 Civic VX? I do have cover on very front but yes no cover where VSS is located. Hmmmm now i'm confused. lol. Look what i found but this may or may not be full cover. Now i don't know. So are you basically saying 92 Civic VX has no full cover by design correct? If that is the case me buying this cover below would be waste
1992-2012 Honda Civic Engine Splash Shield - Replacement, Direct Fit, Plastic, Lower engine cover - JCWhitney
Old Jun 17, 2015 | 12:04 PM
Buy these^ too. Should be cheap at junkyards.
Old Jun 17, 2015 | 12:33 PM
tony_2018's Avatar
Fish Twig
Yes, the splash guard, it does not extend to the rear part of the engine, your vss is located in the rear of the transmission.
Old Jun 17, 2015 | 12:40 PM
The splash guard offers important water splash and road debris damage protection throughout the engine bay.
Old Jun 17, 2015 | 01:20 PM
StewieVX's Avatar
Default Re: 92 Civic VX - Odometer or VSS is not working after heavy rain
Thanks guys and Tony i just checked there ain't nothing where VSS is at. I have unplugged it just now to dry it up from moisture as it was still acting up. It was sporadically working.
I bought the grease and will seal up once it dries up pretty good. I can't tell if it's corroded but maybe i should use break cleaner inside the plug to clean it up?
Old Jun 17, 2015 | 01:53 PM
tony_2018's Avatar
Fish Twig
Default Re: Odometer or VSS is not working after heavy rain
K....
Old Jun 17, 2015 | 01:54 PM
tony_2018's Avatar
Fish Twig
I spy corrosion..
Old Jun 17, 2015 | 01:55 PM
^The VSS terminals look corroded, though the zoomed picture is not focused.
Clean the corrosion from the VSS terminals, and depin the VSS wire harness connector. If necessary, cut the pins from the wire, resolder to clean wire, and then repin to the connector.
Old Jun 17, 2015 | 02:10 PM
K....
My point was that just because the splash guard does not cover the entire bottom of the engine bay doesn't mean it fails to offer more extensive water splash protection in engine bay. With the car driving forward, most water would enter at the front bottom side of the engine bay where the splash guard is located.
Old Jun 17, 2015 | 02:20 PM
StewieVX's Avatar
Thanks guys. I will take better focused pic soon but ron you lost me here.
Sorry i'm a noob here but what should i clean with what? Inside the vss plug or plug itself connected to bunch of wires. What should i clean it with?
Old Jun 17, 2015 | 03:19 PM
StewieVX's Avatar
I think i found an issue. When i was cleaning the inside of the plug little piece of metal came out. I think plug was corroded and snaped while i was cleaning it. Now it's done for good.
I placed an order for new plug $7 and new vss sensor $7 as well on ebay. For this much it's not worth messing around with. $14 and i will get this replaced. I will report once it's installed.
Thank you so much for help.
Old Jun 25, 2015 | 01:50 PM
StewieVX's Avatar
I have successfully replaced plug, i cut it and soldered in new plug to wires and since VSS was $7 and brand new (ebay) i have also replaced that as well. It works all well now. I believe issue was brittle (on the inside) worn out plug not vss but since both were so cheap I replaced both. VSS looked very good on the inside. No rust at all. Had few small pieces of metal shaving there. I have used dielectric grease to isolate and also i have used electrical tape everywhere twice wrapped. No chance of water getting there anymore. I forgot to grease inside vss and pin itself. Not sure if that's a big deal or not but it's done now. Thank you very much to everyone for great feedback.
brians356
Oct 28, 2016 09:35 AM
Kimberly941
Jan 4, 2015 09:05 PM
Barbecue
Aug 24, 2012 08:41 AM
spens 91 Ef
Feb 7, 2009 11:46 PM
