Sleeved 85m GSR, B16, Type R
Old Jun 14, 2015 | 06:44 PM
Turbo_DOHC's Avatar
Default Sleeved 85m GSR, B16, Type R
So I keep reading about sleeved B series blocks bored to 85mm when you guys run them do you do it on a stock combustion chamber (81mm or whatever it is) or you do you guys get the head machined to accommodate the extra 4mm?
Old Jun 14, 2015 | 06:50 PM
Joe Forrest's Avatar
Default Re: Sleeved 85m GSR, B16, Type R
I believe stock sleeves are good up to 500hp and they can be honed to fit
Old Jun 14, 2015 | 07:51 PM
NotARaCist's Avatar
I never narc'd on nobody!
That's not at all what he asked, Forrest.
This question would be better suited in the FI section, but I believe most people go with the stock combustion chamber.
Old Jun 15, 2015 | 04:20 AM
DumpdEJ6's Avatar
I like the tuna here
I would imagine with stock combustion chambers and 85mm bores, you'd want to calculate your piston-to-deck height very carefully lol.
Old Jun 15, 2015 | 04:58 AM
Turbo_DOHC's Avatar
Wouldn't that cause like detonation gaps tho? Since both diameters do not correspond.
Old Jun 15, 2015 | 06:59 AM
civic-steve-94's Avatar
After 82mm the combustion cambers should be opened up to match bore.
Old Jun 15, 2015 | 06:51 PM
93ls10.0's Avatar
I run a 85mm block with a 84mm chamber head
Old Jun 15, 2015 | 07:10 PM
DC4KiD's Avatar
Not necessary to open up the cylinder head chambers. You'd have to make sure to check for piston-to-deck height for clearance, as Ryd2TheMax said below.
Old Jun 15, 2015 | 11:13 PM
wantboost's Avatar
Who is Mr Robot?
This came from the EJ/EK section didn't it?
Typically people open up the bore of the combustion chambers as well... some don't, however it doesn't make much sense not to do it unless you're broke or something.
Like they've said, it can cause issues with clearances depending on things
Old Jun 16, 2015 | 12:41 AM
Kevinio's Avatar
I can understand you will get more swirl into the combustion chamber with such a small squish.
RACEPAK
Sep 10, 2014 07:39 PM
clewis152
45
Aug 13, 2012 05:57 AM
kev o DC
Jul 16, 2008 02:47 PM
Junglesnake
Sep 8, 2005 08:17 AM
JeremyL
Apr 9, 2003 10:30 AM
