Problems running 84mm block with a stock head?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junglesnake »</TD></TR><TR><TD CLASS="quote">Is it really neccessary port the combustion chambers? </TD></TR></TABLE>
NOPE!! I made 616whp with a bone stock head with just valvesprings and retainers in it. 84mm Sleeved block sir. You will be fine
I have been 84mm on a couple motors with the same b16 head. No problems whatsoever. Right now I am running 84.5mm with a b16 head and stock combustion chambers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elinetics »</TD></TR><TR><TD CLASS="quote">wouldnt it raise compression? </TD></TR></TABLE>
not if you go with low comp pistons for whatever bore size your going with.
if u want to make the most power u can ands u have the cash for then do it sum guys r making 400 hp on 20+ boost pressure but if u build the head alittle . u could be making that aT 15 pounds of boost instead of 20+. also less stress on motor
What about the other way around? Smaller bore on the block than on the head.
Just had to ask and break up this thread a bit. (no I don't have this problem...yet).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808 DB8 »</TD></TR><TR><TD CLASS="quote">I have an 84mm GSR with a completely stock GSR head. Jeff Evans tuned it for me and its making 555hp right now.
That is exactly what I am shooting for. By completely stock, I assume you mean stock springs and retainers? Do you have a dyno, as I would like to see your power band? Also, what turbo are you running?
Thanks
</TD></TR></TABLE>That is exactly what I am shooting for. By completely stock, I assume you mean stock springs and retainers? Do you have a dyno, as I would like to see your power band? Also, what turbo are you running?
Thanks
Yes, completely stock. I plan to put in my Ferrea springs and retainers though, as I am taking it up to 8500. I do have a dyno chart, but its not too clear. Im hoping Jeff will post it soon. My turbo is a Full Race T3/T67 H.O. The car did make 605 though it was too lean for Jeffs liking. So it was turned down to 555.
projectef
10
Jul 19, 2006 07:37 AM
gelok
Feb 16, 2004 08:13 AM
