light bulb help: auto transmission in gauge.
So i figured out the light bulb replacement for the automatic shifter light bulb. But what about the one in the gauge cluster? It seems the light in D4 just went out. Can this be replaced?
Make/Model/yr? (read the rules sticky too)
But I believe they can all be replaced, just pull the cluster, then the auto-tree off it and replace.
While you're there, change them all to LEDs
Sorry I got too excited, 98 Honda Civic DX. It seems these are unique after pulling the cluster since they are long base t5 type of light bulb.
I ended up replacing the bulbs differently because I want the others to work still. Also I had spare LED bulbs so I used that instead with a little tweak...
LED lights are extremely bright. At least the light doesn't dim anymore when other lights are also on.
Zhu962
Nov 18, 2008 07:23 PM
b16_madman
Dec 20, 2004 04:22 PM
