Oxygen sensor question
Old Jun 11, 2015 | 05:56 PM
Zuvi00's Avatar
Default Oxygen sensor question
Doing the hx to ex exhaust conversion. Can I use ex oxygen sensors or do I have to use the hx sensors?
Thanks everybody
Old Jun 11, 2015 | 06:28 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Oxygen sensor question
https://honda-tech.com/honda-civic-d...sting-3002401/
There are pieces of required, critical information you are failing to give us, that will affect the answer you are given.
Old Jun 12, 2015 | 03:52 AM
Zuvi00's Avatar
Cousin has a 1997 civic hx. Bought the header and cat from an ex
That had the o2 sensors still in them. Can I just use those o2 sensors from
The ex or do I have to use the hx
Old Jun 12, 2015 | 05:48 AM
slogfilet's Avatar
Is the HX a manual or CVT?
Old Jun 12, 2015 | 06:50 AM
Zuvi00's Avatar
Manual
Old Jun 12, 2015 | 09:59 AM
slogfilet's Avatar
The manual HX used a 5-wire O2 sensor, so the sensors are definitely not the same. Are the sensors in the same location on the EX and HX?
Old Jun 12, 2015 | 10:48 AM
Zuvi00's Avatar
I haven't seen anything yet, but from what I've gathered is the top one is in the same general area. The second one is further back and needs the wiring extended
Old Jun 12, 2015 | 11:06 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
HX has a tri cat or whatever it's called, like the DX/CX/LX has.
OP if your cousin is doing this for HP gains, don't, it's a waste of time and money just sayin'.
Old Jun 12, 2015 | 04:00 PM
HondaPartsHero's Avatar
Technical Hero
If you are using the HX ECU you'll throw a Cat code and O2 code if you use that manifold and those EX sensors. Are you also swapping over the entire exhaust with the EX cat?
Old Jun 12, 2015 | 04:27 PM
Zuvi00's Avatar
Putting on an EX header and cat and an aftermarket cat back
Old Jun 13, 2015 | 01:29 AM
Technical Hero
You have to reuse the primary from the HX (5 wire) and use any of the 4 wires you have for the secondary
Old Jun 13, 2015 | 03:01 AM
Zuvi00's Avatar
Thanks everybody. Appreciate it
grsst3
Honda Civic (2001 - 2005)
Jul 1, 2013 11:35 AM
98CivHx
Sep 6, 2006 08:40 AM
ap1driver
Sep 15, 2004 08:10 AM
civicnar
Apr 7, 2004 04:24 AM
2000blackgsr
11
Sep 11, 2003 08:33 AM
