Transmission & Drivetrain Gearboxes, Differentials, Clutches
What's the best tranny fluid to use??
Old Jun 9, 2015 | 12:20 PM
5luishernandez5's Avatar
Default What's the best tranny fluid to use??
I have a s4c tranny and I just wanna see what's the best tranny fluid I can get for it?
Old Jun 9, 2015 | 05:45 PM
Runnerdown's Avatar
Default Re: What's the best tranny fluid to use??
There is no best fluid. What are you using for ? High power/stock/endurance racing ?
Old Jun 10, 2015 | 08:51 PM
Just endurance racing.
Old Jun 11, 2015 | 01:09 PM
PSI GUY's Avatar
I've tested them all, for endurance racing, most of the guys I build trannys for use the Redline Shockproof oil. For extended periods of heat and abuse it seems to keep everything in check. For street cars it's hard to beat the OEM Honda MTF, I do use the Amsoil MTF from time to time if it's available but it is more costly. Royal purple synchromax seems to dissolve carbon synchros so I do not recommend it in a transmission that is modified with carbon parts, stock brass is okay. Basic rule for me is if you have brass synchros, doesn't matter what it is you can use conventional oil/fluid, if you have carbon or kevlar parts or anything high performance you should use a synthetic fluid.
Old Jun 12, 2015 | 07:59 AM
Aquafina's Avatar
Torco RTF is the best fluid for any type of racing or power level, period.
Old Jun 13, 2015 | 11:27 AM
94EG8's Avatar
Seagull Management
Ben, have you tried Torco? I've tried the MTF (have not tried the RTF) it's really nice stuff.
Old Jun 15, 2015 | 05:29 PM
PSI GUY's Avatar
Yeah, forgot about Torco, the MTF is good for the street but the RTF is the only fluid recommended by MFactory for their products and it does work well. I don't bring it in often as I have to buy it by the case and it's expensive.
Old Jun 15, 2015 | 07:25 PM
94EG8's Avatar
Seagull Management
I'm not sure about the RTF but I used to buy the MTF from East Coast Performance up here in Miramichi and you could by it by the 1L bottle. It comes from Lenco Trans.
YZFR6
Nov 29, 2011 12:21 PM
zedlep
Feb 12, 2009 09:45 AM
shaft627
Acura TL, RL & ZDX
Apr 15, 2006 07:48 AM
drptgsr
Feb 9, 2005 11:14 AM
Prelude Vtec 23
May 3, 2003 07:35 AM
