1999 Civic DX Randomly dies at cruising speed!
Old Jun 7, 2015 | 07:56 AM
OregonDucks's Avatar
Default 1999 Civic DX Randomly dies at cruising speed!
This problem just started happening yesterday while driving home. I was just cruising along at 55mph then all of the sudden the car just shut off. All the gauges went off like you shut off the car but the radio was still working. So I pulled over and it started right back up. Happened twice. It has never happened before. I imagine this is a very open ended question but just figured I would see if anyone else had this happen and what you did to remedy it.
Old Jun 7, 2015 | 10:16 AM
Default Re: 1999 Civic DX Randomly dies at cruising speed!
And its a stock d16y7 engine. No swaps or mods beside an intake and catback exhaust
Old Jun 7, 2015 | 11:14 AM
NotARaCist's Avatar
I never narc'd on nobody!
Is the CEL on? Does it work? When it cut off, did the CEL come on? When it does it again, check for a CEL, and pull the code. You'll most likely need to do this without turning the car off.
Old Jun 7, 2015 | 03:16 PM
I didn't notice a CEL at the time. There is not one on right now. What is the easiest way to check if the CEL light is working? Should it illuminate when initially turning the key forward?
Old Jun 7, 2015 | 03:31 PM
NotARaCist's Avatar
Yep, when you turn the key to ON(II), the CEL should come on for ~2 seconds, then turn back off.
Old Jun 7, 2015 | 05:40 PM
Ok so CEL illuminates when turning the key. Took it to the local auto parts store here and had them check for codes and there were none. Also randomly after being warm now sometimes it takes a couple of key turns to start. Most of the time its right away but sometimes it takes some cranking before it starts.
Old Jun 7, 2015 | 05:57 PM
NotARaCist's Avatar
Get one of these, use it, and tell us what color your spark is on all four. It's called a spark plug tester - you can find it at most parts stores for $10-$15. Ideally, do this test immediately after the car has died on you. Alternatively, do it when your car is having a hard time starting.
Your coil and/or ICM might be on their way out.
Old Jun 8, 2015 | 01:23 AM
eschel's Avatar
Hi guys, i have a 1999 civic (or known is south africa as the ballade) and my car does something similar. The car has a b20b engine in it and it did the same thing. I tried to start it again but just wasted my battery. Could it be my altenator or ecu that is causing it?
Old Jun 8, 2015 | 09:39 AM
doneking's Avatar
You might want to look into the ignition switch. I had a similar problem and the ignition switch was the issue. Check this thread out.
https://honda-tech.com/honda-civic-d...lling-2809649/
Good Luck,
DK
Old Jun 8, 2015 | 11:34 AM
eschel's Avatar
Thanx for the response king, i failed to mention that before the car dies, all the gauges dies and the car misfires. The lights also goes really dimm when that happens
Old Jun 8, 2015 | 02:53 PM
CivicxTree754's Avatar
Photogenic
Loved
Honda Acura ignition (no spark) troubleshooting tutorial - How to
Link to test the ignition switch
Old Aug 29, 2015 | 08:11 AM
Originally Posted by CivicxTree754
Would this also cause the car to shut off while driving?
So its happened various other times and at various speeds. Checked for spark right after it did it one time and spark was fine. Sometimes now it doesn't start right back up but everytime when you attempt to start it does turn over then dies within a second. It does fire then just stops. All the sudden it will just crank over and your good to go. Weird thing is, and I have tested this is, that it happens way more when the temperature outside is above 90. Also seems to happen a lot of times coming off of the throttle or cruising at a set speed. I have tried a couple of times to pop the clutch when it has happened at near freeway speed and that never works. You have to pull over and turn the key off then back on. I know that was wordy but just wanted to give some detailed experiences so maybe it will lead us somewhere!
Old Aug 29, 2015 | 08:39 AM
turbohatch96y7's Avatar
Main relay
Old Aug 29, 2015 | 09:32 AM
I would have thought this but I have never had a no start from cold. And even when it dies and you turn it back on its definitely getting fuel cause it fires right away and just dies. Guess it could be worth a shot picking a couple up from a junkyard!
Old Aug 29, 2015 | 01:14 PM
hondur's Avatar
Dur Da Dur
5 Year Member
have advance auto parts do an electrical system test. Alternator, battery, and parasitic loss
its free.
Old Aug 29, 2015 | 09:13 PM
eghatch9295's Avatar
Stancetard Hate Monger
my money is on switch, once had a 99 accord (has a recall on it), did the exact same thing. test first, as always
Old Sep 4, 2015 | 07:20 AM
Are we talking about the lock cylinder or the wires with the pigtail plugs on them? You can buy both I noticed!
LockSmart LA10165 - Ignition Starter Switch | O'Reilly Auto Parts
Old Sep 8, 2015 | 11:22 AM
Has anyone used one of these?. Seems like oreillys is the only one who sells it like this. All others have it as complete and also costs twice as much!
Old Sep 8, 2015 | 08:13 PM
tony_2018's Avatar
Fish Twig
Honda sells them too..
Old Sep 9, 2015 | 01:26 AM
never gone aftermarket, can't speak to the quality of that part, but that is what i think you need.
Old Nov 3, 2015 | 09:08 AM
Just wanted to update this thread and say thanks to everyone! Replacing the ignition wiring after the key cylinder worked like a charm. Nothing has happened since. I also ended up using the Honda OEM part as suggested also! It was only a couple bucks more than the aftermarket part. One again thanks everyone and I am so happy to get that very annoying problem fixed !
Mount Reverie
Jun 25, 2011 01:46 PM
wtg13
Jul 2, 2009 08:11 PM
lilpastrana
Feb 27, 2007 04:59 PM
CompanyFlow
Acura TL, RL & ZDX
Oct 26, 2006 08:24 AM
slowpokecivic
10
Mar 9, 2006 02:23 PM
