H22 limp mode
I've been fixing and fixing things all around the car since we put this wngine back in it after it was leaking everything checks out okay but yet the car is in limp mode no check lights anymore
Disconnect the battery for 10min first. Also I'm pretty sure it doesn't throw a code for timing being off, but that could make it feel like it's in limp mode. You'd be surprised how poorly an engine will run off a couple teeth. You'd think it just wouldn't start at all, but it will
I did find the problem the little box in the left fender had busted when someone crashed into my
Car I put a new one in seems to be fine now. THANKyou everyone for your help I did try everything you Guys said also so thanks
EK22Tim
Dec 24, 2002 08:53 AM
