check engine stop working when jumped
Old Jun 5, 2015 | 02:00 PM
carlos8's Avatar
Default check engine stop working when jumped
Hi, I'm fighting some bugs in my car the last days, today install a new set of spark wires. Went to jump the service plug but the check engine light don't turn On or blink.
She turn ON the 3 seconds when turn the switch and turn OFF.
How I check for continuity in the service plug?
Civic 97 ex
ls vtec
p28 crome pro + tuned
Thanks
Old Jun 5, 2015 | 11:03 PM
carlos8's Avatar
Default Re: check engine stop working when jumped
Any help on how to test the circuit?
A13 is the MIL pin, What I'm looking there ground or voltage?
Old Jun 6, 2015 | 03:53 AM
v4lu3s's Avatar
RTFM
So the check engine light comes on like normal with the ignition, then turns off like normal? Then when the light is not on, you jump the connector and no codes are displayed? If that is all correct it sounds like everything is working properly.
Old Jun 6, 2015 | 07:08 AM
Former User's Avatar
Sounds like an ECU problem.
Old Jun 6, 2015 | 07:31 AM
carlos8's Avatar
Found the problem A22 no continuity, wiggle it at the service connector end and work. Need to find one and solder it.
Thanks fro the responses.
jus_spooln_wicha
Sep 20, 2008 07:25 AM
lowered94accord
Mar 16, 2007 08:27 AM
originalbadbob
Jun 24, 2004 10:17 PM
Todd
Dec 10, 2002 08:04 PM
