is the delsol radiator a dual core???
only if it is a Del Sol Si, with the B16A in it, and yes it will bolt up to your stock 93' civic. the SOHC'd Sol's have the same rad. you have. I have a del sol Dual core rad. in my 92' DX HB
hope this helps.
hope this helps.
just find an auto radiator as well. i have an auto radiator..its dual core compare to the dinky single core i used to have
It will bolt up just fine. I wouldnt source an automatic radiator only because I think it would have an extra tank for the automatic transmission cooler. No?
i know for a fact the automatic 92-95 civic ex radiator's are dual core, my best friend has one... i asked him if he was going to upgrade his "single core" radiator after the turbo install he said, "no, it's already a dual-core" i looked, yep, it was only on the auto version though. when i got my ls, i got the del sol vtec dual-core installed, perfect drop in, temp gauge never goes above 1/4 of the way even when running all night.
here is my question:
is the DELSOL dual core THE SAME AS the Civic Auto Dual Core??
Coz if i get those Auto Dual Core at the junkyard, it might be cheaper !!!
thgnks
thgnks
they are the same as in size and fitment, his is a honda one, mine was an aftermarket which "looked" different. apples and apples. why don't you just look at both ones in the junkyard?
thgnks
thgnks
HELP!
Sorry to intrude in the Civic/Del Sol forum, but i found this with search. I was told by a mechanic that Integras also use single/dual cores respectively for their manual/automatics, but have heard nothing else to substantiate this. Do any of you know if this is true? It not, what's my best option considering I can't have anything thicker than stock (for the sake of my turbo/fans fitting)?
Thanks in advanced!
Nick
Thanks in advanced!
Nick
is there a difference between the auto del sol si radiator and the manual one? because i did an auto to manual swap a year and a half ago and my temperature gauge never goes high than 1/3 of the way and when im driving on the freeway expecially on cold nights the gauge is only 1 to 2 bars up some times even on the lowest one. although i have seen i go 1/2 way on a very rare ocassion. should i be concerned about this? or should be something to be proud about?
ImprtTuner88
134
Jun 14, 2005 08:29 AM
ShakesTheKlown
19
Jan 7, 2004 04:43 AM
im_poor
14
May 29, 2003 11:03 PM
Looks beefier and fits perfect in my 93 CX
