jdm d15b vtec crankshaft - What engines have same crankshaft?
Old May 31, 2015 | 02:41 PM
Ef_Life's Avatar
Icon2 jdm d15b vtec crankshaft - What engines have same crankshaft?
I need a jdm d15b vtec crankshaft. I wanna know if any other engine has the same crankshaft.....Thank you
Old Jun 1, 2015 | 09:38 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default re: jdm d15b vtec crankshaft - What engines have same crankshaft?
Do you have a bad one you can measure the mains on?
If the mains are also 45mm like the rod journals then all the D15B2/7/8 cranks are the same size as the D15B.
The other part I would question is do the journals have 1 or 2 oil holes per journal?
I'm assuming you have a bent crank or some other problem with the d15b crank causing you to need a replacement.
Old Jun 2, 2015 | 05:57 AM
Former User's Avatar
Default Re: jdm d15b vtec crankshaft - What engines have same crankshaft?
There are two versions of the D15B - fuel efficiency and performance. Which are you talking about?
redturboeg
Jul 2, 2010 02:55 PM
rebo0t
May 24, 2007 12:19 PM
furiouscivic
Feb 20, 2007 03:59 AM
