Climate Control Unit and other thing not working??
Old May 29, 2015 | 04:54 PM
EGToFlyy's Avatar
Default 94 Civic EG: Climate Control not turning on
I've searched this up online and I have found nothing.
I have a stock 94 Civic Hatchback that I recently purchased and I am having issues with my Climate Control Unit. The lights aren't lighting up and it's not working. I've checked all my fuses and they're all good.
Also my stereo doesn't seem to turn on either. I've checked fuses and still nothing.
The cigarette lighter isn't working either.
Would I happen to have bad wiring throughout the whole car?
Is there anything else I should check?
Old May 29, 2015 | 05:07 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Climate Control Unit and other thing not working??
You should start off by checking this thread, and adjusting your post properly. You're missing a good chunk of rather critical information.
https://honda-tech.com/honda-civic-d...sting-3002401/
Old May 29, 2015 | 05:19 PM
Former User's Avatar
Oh man. Some day new members will understand the importance of car information and reading the forum Rules...I hope.
Old May 29, 2015 | 05:23 PM
NotARaCist's Avatar
There has to be a way for you guys to force people to read the rules and FAQ stickies before creating a post. There HAS to be a way.
Old May 29, 2015 | 05:25 PM
Ideas?
Old May 29, 2015 | 05:52 PM
NotARaCist's Avatar
Above my pay grade, good sir. Is the footer information still accurate, as far as the forums running on vBulletin 3.8.7? If it is, I can see if I can find anything.
Old May 29, 2015 | 05:56 PM
If you do, please PM me.
Old May 29, 2015 | 10:19 PM
EGToFlyy's Avatar
Lol? Where are all these "rules" at that I missed?
Old May 29, 2015 | 10:22 PM
Correct, you missed them, but they're hiding in plain sight.
Old May 29, 2015 | 10:26 PM
EGToFlyy's Avatar
Obviously I did. I was in a hurry. I apologies. Is this better or is it still terrible?
Old May 29, 2015 | 10:27 PM
Is this better...?
Cluster back lights work?
Aftermarket radio installed?
Old May 29, 2015 | 10:34 PM
EGToFlyy's Avatar
Cluster turns on and my clock does too. I rewired my radio twice just to make sure I didn't wire something up wrong but nothing. Perhaps I need to buy new harnesses?
Old May 29, 2015 | 10:42 PM
The climate control lights are connected to the dimmer switch and require two wires to work - Red and Red/Blk.
Radios often use the same two wires to have dimmable lights. Perhaps you miswired them.
To work, the radio requires voltage from two fuses - 23 and 32. Check both.
Check whether the cig. lighter has two wires connected to it - Yel/Red and Blk. It may also interest you that the cig. lighter also gets voltage from fuse 23.
The cig. lighter also has a light, which uses the same dimmer circuit Red/Blk wire above.
Old May 29, 2015 | 11:13 PM
EGToFlyy's Avatar
Thanks! Will check it out tomorrow!
egdro
May 22, 2013 04:40 PM
EG8AI
Mar 25, 2009 11:15 PM
jDMJeRk
Jan 19, 2005 10:22 AM
Hehehe I just
May 3, 2004 02:31 PM
