Re: automatic transmission shifts too quickly
Old May 26, 2015 | 07:39 AM
lhanse13's Avatar
Default Re: automatic transmission shifts too quickly
I know this thread is pretty old but i'm having the same problem with my civic. I just replaced the d15 with a d16 but kep the dual port fuel injection. THe car starts out really slow and shifts to 2nd gear at 5-10mph and lugs. Once the rpms gets up it feels MUCh better, feels peppy and can get up to speed quickly. However when taking off it is slow to the point where i think there is a problem.
Is there a solenoid i can replace? It's a 1991 civic jdm zc motor with d15 transmission. THe tranny was just serviced not long ago. What about a torque converter? Is it the entire transmission? Thanks
Old May 26, 2015 | 09:57 AM
ejv8s10's Avatar
Adjust your transmission cable. I think the manual calls it a throttle control cable. It is an easy fix.
Old May 26, 2015 | 09:59 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
There is a cable adjustment from the throttle body to the automatic transmissions. If it is out of adjustment, the shift points will be all wrong.
If you google 92-95 factory service manual, you can get the adjustment procedure for your transmission. After that if that doesn't fix your issue, the FSM will have further steps and repairs you can do.
I moved your post into it's own thread and referenced the old thread. I'm sure you are not aware but that is the method used on these boards instead of bumping old threads. Explanation provided purely as an FYI.
Hope this info helps.
Old May 26, 2015 | 03:19 PM
Jimi Hondrix's Avatar
This may help:
1995 civic dx auto transmission problem | ClubCivic.com - Your Online Civic Community
Exdeath
Oct 5, 2010 03:54 AM
mr2isaac
Mar 8, 2009 06:22 PM
rayccfhk
Nov 1, 2007 12:36 PM
Rice4me
Jul 4, 2001 05:24 AM
