Built Del Sol - fx350 clutch isnt engaging!!
i have a built del sol with 3k miles on everything I bought the clutch from synchrotech and clutch is fx350 from clutch masters.
It started off the car giving me troubles getting into gear when it was cold but once it was warmed up it would be fine but now it just wont go into gear at all
ive bleed the clutch a lot used 3 bottles of brake fluid
I've replaced the master and slave cylinder which I purchased from the dealer ship.
I also dropped the tranny and the clutch is fine..no spring popped or bent plates
I am clueless and losing my mind!!!
the clutch is stiff from top to the floor
and when the car is off I can go through all the gears but when its running I cant
and when its running and if Im pressing or not pressing the clutch and trying to put it into 1st gear it doesn't grind...but the car moves forward a bit
When the engine is off, and you shift into any gear, have you verified it's actually goes into gear?
Is the clutch pedal adjusted to proper height?
If you start the engine with the transmission in first gear, will the car move normally?
sorry about that I just logged into my computer instead of my phone
but yes it does go into gear.
i didn't adjust the pedal height i left it how it was when it was working properly
yes the car does move when i try to start it in gear
my problem is the clutch not working.. i cant find the issue i thought it was the hydraulic system but ive replaced everything and bleed it but still wont go into gear when the car is running.
You must read all of my questions and answer them directly. Otherwise, this thread is going nowhere fast.
throw it in 1st gear, keep the clutch pedal down, try to start the car. If it still lungs forward than you did not install the clutch properly.
It must be an installation issue/product issue.
You said you bled the system which you couldn't properly do if you had hydraulic problems. You said if you put it in first gear and start the car it moves so I assume you could even drive the car without the clutch by rev matching. You will have to take off the gearbox again and examine the clutch.
My car was running fine but then it was hard to put into gear when it was cold. When it warmed up it would go right in but now it doesn't go in at all
sol817
13
Jul 20, 2015 05:00 PM
yaba3800
Sep 14, 2008 02:57 PM
PatrickGSR94
17
Aug 3, 2006 08:36 PM
