y7/y8 conversion misfiring and has engine surge at light throttle
Wats up everybody well I recently did a y8 head swap onto a y7 block along with the manifold and everything about a month ago.. wired up vtec solenoid and pressure switch along with a ks to a p2p a34 ecu with the stock harness just added a few wires. Well it had seemed to be running fine and strong with the exception of the high idle from the iacv rewire ...up until I had an exhaust put on about 2 weeks ago 2.5 in. Piping with no cat so no 2ndary o2 neither but was never a problem prior..since then I've been having an intermitent engine surge during light throttle along with poor performance and a bad misfire but not always it only seems to happen during the warm afternoons never during cool mornings or nights ...if I go w.o t the problem seems to go away but still sluggish performance ...ive changed the plugs wires cap and rotor along with a new 02 sensor and fuel filter is there anything else that could cause this to happen I've checked timing and all seems well but not 100 percent cuz I couldn't get the crank pulley off during swap just hit it with the timing light after and everything checked out .is there anything else that it could be ...
Gator417
Sep 15, 2015 06:17 PM
combz
Jul 15, 2007 02:59 PM
1BlackHatch
Nov 10, 2005 12:55 AM
