I put my car in park press the gas and at 4000 rpms it chokes.
Old May 19, 2015 | 04:28 AM
Witness327's Avatar
Default I put my car in park press the gas and at 4000 rpms it chokes.
I am not sure what this could be and while driving it does the same when I hit 70-80mph.
Old May 21, 2015 | 11:22 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: I put my car in park press the gas and at 4000 rpms it chokes.
Check for any codes stored in the memory.
If there is an issue the car may be in limp mode, Tachs are not that accurate and are known to be wildly off.
Next check fuel pressure, if the pump is failing or the filter is clogged, the system may not be able to provide enough fuel and the car engine is simply starved for gas.
Check your air filter, if it is clogged the engine will not be able to breath.
Old Jun 20, 2015 | 06:16 AM
Witness327's Avatar
Thank you I'll look into this. I Do Have A Couple Of Lights On THE das. One is a check engine and maintenance needed. Also when I am driving I am noting that when I put it in park reverse or drive it will jolt the car.
93SIRII
Feb 7, 2007 06:44 PM
modulo_s
Sep 21, 2006 05:54 PM
blk_eg4
Aug 3, 2006 08:27 PM
skunk2gsr
Jul 18, 2004 07:52 AM
92greensr
Jan 17, 2004 09:53 AM
